When the number is bigger than 999, it use coma ( ,) to separate the decimals. This is correct.
But when the number is smaller than 1.000, it use the point ( .) to separates de decimal.
It is quite confusing.
The better, an image
2013 , but, where I can see the sp?
Under Help-about, I can only see a lot of patents numbers.
Well ,the main problem is I don't know where to chage the decimal separation to coma.
If if graph option I click " use miles separator" it use point coma or point depending of the value, like I explained avobe.
If I unselect " use miles separator", I can see just the point as decimal separator.
Version and sp?
Happening on all files? All types of outputs?
