Is there a possibility to form directly polylines when you convert a slddrw to a dxf-file? I tried to use Fit-spline, but that doesn't really work.
Now i have to use illustrator or draftsight to make the lines joined together and i want to skip this time consuming task.
When you do Save As from the solidworks drawing and pick dxf format, then click the options button on the bottom. This is probably what you want.
