1 Reply Latest reply on Jun 17, 2014 10:58 AM by Bryan Compton
    Set SwBomFeat = SwFeat.???
    Yong Ning
      Private Sub ll()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
          Set SwApp = GetObject(, "SldWorks.Application")
          Set SwModel = SwApp.ActiveDoc
          Set SwDraw = SwModel
        Dim SwFeat As Feature, SwBomFeat As BomFeature
          Set SwFeat = SwModel.FirstFeature
          Do While Not SwFeat Is Nothing
            If SwFeat.GetTypeName = "BomFeat" Then
              Debug.Print SwFeat.Name, SwFeat.GetTypeName
              Set SwBomFeat = SwFeat.GetDefinition
              Stop
            Set SwFeat = SwFeat.GetNextFeature
          Loop
      Option Explicit
      Dim Dic As New Dictionary
      Function DicShowConf(SwComp As Component2)
         Dim SwModel As ModelDoc2, ConfStr
            ConfStr = SwComp.ReferencedConfiguration
            Set SwModel = SwComp.GetModelDoc
             If Not Dic.Exists(SwModel.GetTitle) Then
                If Not SwModel Is Nothing Then
                   Dic(SwModel.GetTitle) = ""
                   SwModel.ShowConfiguration ConfStr
                   Debug.Print SwModel.GetTitle, ConfStr
      End Function
      Private Sub ShowConfigOfComponent()
        Dim oDic As New Dictionary, Str, ii, jj
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, oSwModel As ModelDoc2
        Dim SwSelMgr As SelectionMgr
          Set SwSelMgr = SwModel.SelectionManager
        Dim SwAssy As AssemblyDoc, SwComp As Component2, oSwComp As Component2
          Set SwAssy = SwModel
        Dim SwConf As Configuration, SwRootComp As Component2
          Set SwConf = SwModel.GetActiveConfiguration
          Set SwRootComp = SwConf.GetRootComponent
        Dim ChildComp, oChildComp
          ChildComp = SwRootComp.GetChildren
          For ii = 0 To UBound(ChildComp)
             Set SwComp = ChildComp(ii)
             DicShowConf SwComp
             If UCase(SwModel.GetTitle) Like "*SLDASM*" Then
                oChildComp = SwComp.GetChildren
                Stop
                For jj = 0 To UBound(oChildComp)
                  Set oSwComp = oChildComp(jj)
                  DicShowConf oSwComp
                Next jj
          Next ii
      help me
      SolidWorks Forums: How can I change the reference config. of a BOM in a draw
      https://forum.solidworks.com/message/146275#146275
      SolidWorks Forums: How to select bomtable in Feature.
      https://forum.solidworks.com/message/396038#396038
      SolidWorks Forums: Get Components in Each BOM Table Row Example (VB.NET)
      https://forum.solidworks.com/message/219723#219723
