2 Replies Latest reply on Jun 23, 2014 4:20 AM by Yong Ning
    SwView.GetBomTable → Nothing
    Yong Ning
      Sub ll1()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
          Set SwApp = GetObject(, "SldWorks.Application")
          Set SwModel = SwApp.ActiveDoc
          Set SwDraw = SwModel
        Dim SwView As View, SwBomTab As BomTable
          Set SwView = SwDraw.GetFirstView
          Set SwView = SwView.GetNextView
          Set SwBomTab = SwView.GetBomTable
          Stop
      Help me.
      How to use the SwView.GetBomTable statement
      SolidWorks Forums: Change in Bend Deduction property not committing.
      https://forum.solidworks.com/message/378049#378049
        • Re: SwView.GetBomTable → Nothing
          Jim Sculley
          The GetBomTable method will only return results if you are using Excel based BOMs.  If you are using normal SolidWorks BOMs, this is not the correct method to use.  You can use IView::GetTableAnnotations or you can use the FeatureManager to walk through the feature tree looking for BomFeature objects.
          Jim S.
              Yong Ning
              Thanks your tips
              Private Sub Getann()
                Dim SwModel As ModelDoc2
                  Set SwModel = Application.SldWorks.ActiveDoc
                Dim SwSelMgr As SelectionMgr, SwBomFeat As BomFeature
                  Set SwSelMgr = SwModel.SelectionManager
                  Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
                  'Debug.Print SwBomFeat.GetFeature.Name
                Dim SwTabAnn As TableAnnotation, ss
                  ss = SwBomFeat.GetTableAnnotations
                  Set SwTabAnn = ss(0)
                  Debug.Print SwTabAnn.Title
                  With SwTabAnn
                     For ii = 0 To .RowCount
                        For jj = 0 To .ColumnCount
                           Debug.Print .Text(ii, jj),
                        Next jj
                        Debug.Print
                     Next ii
                  End With
              Private Sub Main2()
                  Dim Wk As Workbook, Sht As Worksheet, Rng As Range
                    Set Wk = connectXls
                    Set Sht = Wk.Sheets(1)
                    nn = Sht.Range("A65536").End(3).Row
                    Set Rng = Sht.Range("A3:A" & nn)
                  Dim swApp As SldWorks.SldWorks, SwModel As SldWorks.ModelDoc2
                  Dim vConfigNameArr, vConfigName
                  Dim Str, ii, PrtAsm, Conf
                  PrtAsm = "Ellipse.SldPrt"
                  PrtAsm1 = "Shell.SldPrt"
                  PrtAsm2 = "支座BI-F-四六筋.sldasm"
                  Set SwModel = swApp.ActiveDoc
                  vConfigNameArr = SwModel.GetConfigurationNames
                  For ii = 0 To UBound(vConfigNameArr)
                      vConfigName = vConfigNameArr(ii)
                      With SwModel
                         .ShowConfiguration vConfigName
                         Str = "SW-Mass@@" & vConfigName & "@" & SwModel.GetTitle
                         .AddCustomInfo3 vConfigName, "质量", 30, "12"
                         .CustomInfo2(vConfigName, "质量") = """" & Str & """"
                         Conf = Rng(ii + 1, 1)
                         Str = "SW-Mass@@" & Rng(ii + 1, 2) & "@" & PrtAsm
                         .AddCustomInfo3 Conf, "封头质量", 30, "12"
                         .CustomInfo2(Conf, "封头质量") = """" & Str & """"
                         Str = "SW-Mass@@" & Rng(ii + 1, 4) & "@" & PrtAsm1
                         .AddCustomInfo3 Conf, "筒体质量", 30, "12"
                         .CustomInfo2(Conf, "筒体质量") = """" & Str & """"
                         Str = "SW-Mass@@" & Rng(ii + 1, 5) & "@" & PrtAsm2
                         .AddCustomInfo3 Conf, "支座质量", 30, "12"
                         .CustomInfo2(Conf, "支座质量") = """" & Str & """"
                      End With
                  Next ii
