6 Replies Latest reply on Jun 18, 2014 4:13 PM by Wes Cox
    File Handling for Geometrically Identical Parts, Batch Clone to Property Value
    Wes Cox
      Suppose I have 500 red parts, and 500 blue parts, and any given red part = a blue twin. I've created a property during the creation of the red parts that gives the equivelant part number in the blue twin. Now that I have created, scaled, and detailed the red parts and drawings, I want to clone them.
      I want to run a macro to open the drawings, rename the reference model configurations "default",  pull the configuration level property blue twin value, rename (clone) the red drawing to the blue twin value, rename the referenced part the blue twin value, close. I'll end up with a folder full of red parts and drawings and a folder of cloned blue twins parts and drawings.
      I've spent all mornign trying to create a macro to do this.
      here is the threads I've been referenceing:
      https://forum.solidworks.com/message/266358#266358
      https://forum.solidworks.com/message/266816#266816
      https://forum.solidworks.com/thread/46022
      https://forum.solidworks.com/message/431789#431789
      Thanks in advance if anyone has ideas on how this might work. I've used pack and go for smaller quantities, but it becomes easy to make errors in this situation almost no matterwhat I do-- if I do this process manually.
        • Re: File Handling for Geometrically Identical Parts, Batch Clone to Property Value
          Deepak Gupta
          Would you mind posting an example of red and blue twin files??
              Wes Cox
              The Red files are generated from configurations run off the design table, and this is where the blue twin part number is controlled as a configuration level property. I've attached a sample file that includes the design table- the files I'd actually be looking to clone to blue files are like the case of "Red 1001".
              Thanks Deepak, If you have a way to crack this one I've got to buy you a drink,
                Wes Cox
                Deepak,
                I have this working on the part, to rename the configuration in the red part (configuration is currently titled Red part #) to default......................
                Dim swApp As Object
                    Dim swModel  As ModelDoc2
                    Dim swConfig   As Configuration
                    Dim swConfMgr  As ConfigurationManager
                    Set swModel = swApp.ActiveDoc
                    Set swConfMgr = swModel.ConfigurationManager
                    Set swConfig = swConfMgr.ActiveConfiguration
                    swConfig.Name = "Default"
                Once the configuration is called "Default", I am able to use this macro to rename the part the Blue Part# Configuration level property (I'm calling this property "ACCross" for cross linked designs)
                Dim swApp As Object
                Dim SWmoddoc As SldWorks.ModelDoc2
                Dim ACCross As String
                Set SWmoddoc = swApp.ActiveDoc
                'Use this....To Get the value from the Properties in the CUSTOM tab
                'ACCross = SWmoddoc.CustomInfo("ACCross")
                'Or this....To Get the value from the Configuration Specific Tab
                ACCross = SWmoddoc.GetCustomInfoValue("Default", "ACCross")
                'athName = SWmoddoc.GetPathName     'this gets the full path of the current open document (including filename)
                'Filepath = Left(PathName, InStrRev(PathName, "\C:SW Working Folder\Wes\Macro Experiment and Documentation\ACCross Tesrt"))  'uses to full pathname to get the folder path, to be added to the save as file name
                If (SWmoddoc.GetType = swDocASSEMBLY) Then
                    SWmoddoc.SaveAs (Filepath + ACCross + ".sldasm")
                ElseIf (SWmoddoc.GetType = swDocPART) Then
                     SWmoddoc.SaveAs (Filepath + ACCross + ".sldprt")
                But I have yet to find a way to splice these functions into your macro like this one:
                'Save Sheet Metal Part Drawing As DWG (Custom Property).swp ---------------------------------05/17/14
                'Description: Macro to save active drawing as DWG.
                'Precondition: Any active drawing with a view of Sheet Metal Part having specified custom property.
                'Postcondition: Active drawing will be saved as DWG along with custom property values in the file name in same location as the drawing file.
                ' Please back up your data before use and USE AT OWN RISK
                ' This macro is provided as is.  No claims, support, refund, safety net, or
                ' warranties are expressed or implied.  By using this macro and/or its code in
                ' any way whatsoever, the user and any entities which the user represents,
                ' agree to hold the authors free of any and all liability.  Free distribution
                ' and use of this code in other free works is welcome.  If any portion of
                ' this code is used in other works, credit to the authors must be placed in
                ' that work within a user viewable location (e.g., macro header).  All other
                ' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
                ' without the expressed written consent by the authors.  Use at your own risk!
                ' Written by: Deepak Gupta (http://gupta9665.com/)
                Option Explicit
                Dim swModel         As SldWorks.ModelDoc2
                Dim swDrawModel     As SldWorks.ModelDoc2
                Dim swDraw          As SldWorks.DrawingDoc
                Dim swView          As SldWorks.View
                Dim swFeat          As SldWorks.Feature
                Dim swBaseFlange    As SldWorks.BaseFlangeFeatureData
                Dim Filepath        As String
                Dim sModelName      As String
                Dim sFileName       As String
                Dim Fileprop       As String
                Dim sConfig         As String
                Dim PartThickness   As String
                Dim sMatName        As String
                Dim sMatDB          As String
                Set swDrawModel = swApp.ActiveDoc
                ' Check to see if a drawing is loaded.
                If swDrawModel Is Nothing Then
                        MsgBox "There is no active drawing document"
                        Exit Sub
                If swDrawModel.GetType <> swDocDRAWING Then
                        MsgBox "Open a drawing first and then TRY again!"
                        Exit Sub
                Set swDraw = swDrawModel
                Set swView = swDraw.GetFirstView
                Set swView = swView.GetNextView
                Set swModel = swView.ReferencedDocument
                sModelName = swView.GetReferencedModelName
                ' Determine if there is any view
                If sModelName = "" Then
                        MsgBox "Insert a SheetMetal Part View first and then TRY again!"
                        Exit Sub
                ' Determine if this is a view of a part or assembly
                sModelName = LCase(sModelName)
                If InStr(sModelName, ".sldasm") Then
                    MsgBox "Worsks only for SheetMetal Part Drawings!"
                    Exit Sub
                Else
                sConfig = swView.ReferencedConfiguration
                Set swFeat = swModel.FirstFeature
                Do While Not swFeat Is Nothing
                        ' Process top-level sheet metal features
                        Select Case swFeat.GetTypeName
                            Case "SMBaseFlange"
                                Set swBaseFlange = swFeat.GetDefinition
                                PartThickness = swBaseFlange.ThicknessTableName
                                PartThickness = Right(PartThickness, Len(PartThickness) - 6)
                Case Else
                End Select
                        Set swFeat = swFeat.GetNextFeature
                Loop
                Fileprop = swModel.CustomInfo2(sConfig, "SWBOMPARTNO")  'Change the custom property name here
                ' Get Material details
                sMatName = swModel.GetMaterialPropertyName2(sConfig, sMatDB)
                Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))
                sFileName = Filepath + Fileprop + "_" + PartThickness + "_" + sMatName + ".dwg"
                        If Dir(sFileName) <> "" Then
                            MsgBox "File Already Exists"
                    Else
                        swDraw.SaveAs sFileName
                Or this one:
                'Save Referenced Model As STEP.swp ------------- 05/31/14
                'Description: Macro to save referenced docuemnt in the current active drawing as STEP file.
                'Pre-Condition: An open drawing with one view.
                'Post-Condition: Macro will update the save the referenced model as STEP file in same location as the model file.
                'Please back up your data before use and USE AT OWN RISK
                ' forms of distribution (i.e., not free, fee for delivery, etc.) are prohibited
                Option Explicit
                Dim nErrors         As Long
                Dim nWarnings       As Long
                        Exit Sub
                        Exit Sub
                If swModel.GetPathName = "" Then
                        MsgBox "Insert a View first and then TRY again!"
                        Exit Sub
                If Dir(Left(swModel.GetPathName, InStrRev(swModel.GetPathName, ".") - 1) & ".step") <> "" Then
                  MsgBox "STEP File already exists!"
                        Exit Sub
                  Else
                        swModel.Extension.SaveAs Left(swModel.GetPathName, InStrRev(swModel.GetPathName, ".") - 1) & ".step", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
                Am I on the wrong track trying to combine these?
                Thank you,
                Wes
