Problem with cavitation in a simple model
Question asked by Simone Storace on Jun 16, 2014
Latest reply on Jul 2, 2014 by Simone Storace
let me introduce myself: my name is Simone and I am a novice in this community and in SW.
I've just started to use SW-FS and I immediately found a question about cavitation.
I'll attach 3 pictures and explain:
img 1) -> Contours of static pressure used to find where cavitation can grow, that is the part in which water pressure, at a constant and fixed temperature, drops below the value of the vaporization pressure . So I redo the calculation with cavitation method activated.
img 2) 3) -> contours of pressure and mass fraction of vapor in the second calculation. In this case the pressure seems to have a higher value of pressure than before and now the minimum value is greater than vaporization pressure.
How is possible to have a non-zero value for a mass fraction of vapor with a value of pression greater than vaporization pressure?
Boundary condition:
- Transferred boundary condition in inlet (this is a submodel)
- Fixed value in pressure outlet (P=110000 Pa)
- Adiabatic wall and stationary wall (no rotating zone)
- Temperature =362K
- Vaporization Pressure = 70000 Pa
best regards
Simone
