HI,
I AM LOOKING FOR A WAY TO ADD DIMENSIONS FOR A SKETCH. I USED THE LINEAR PATERN TO DRAW THE SKETCH, BUT I WANT TO ADD THE DIMENSION FOR THE REPEATED SKETCHES AUTOMATICALLY. IS THERE ANY WAY TO DO THIS?
REGARDS
HI,
REGARDS
THANK YOU JAMIL,
ACUALLY I'VE DONE THE RELATIONS (VERTICAL & HORIZONTAL), BUT THE PROBLEM IS WHEN I CHANGE THE ANGLE SHOWN IN THE ATTACHED SKETCH, THE DISTANCE BETWEEN THE TWO PRISMS CHANGES AS WELL. THE ONLY WAY I FOUND IS TO ADD THE HORIZOTAL DIMENSIONS BETWEEN THE POINTS (WHICH IS 5mm IN THE SKETCH). SO DO YOU KNOW ANY OTHER WAY TO FIX THE HORIZONTAL DISTANCE?
Do you actually need dimensions or do you just want the sketch fully constrained? All you need to do to constrain the sketch is put a horizontal relation between 2 of the triangle tips.
