Good morning All,
I'm stumped on an issue I'm having with a very simple part that will not display the flat pattern correctly. I usually don't have a problem with flat patterns on a drawing but with this one I am. I've attached the part as well as "test" drawing. When I drag the flat pattern from the view pallette, it is showing a formed view instead of the actual flat. Everything appears to look correct with the configuration for that particular view and the part flattens out correctly to the proper flat. Stumped......
Thanks for any input.
Make sure that the flat pattern configuration is the active configuration and/or that the flat pattern feature is unsuppressed in the drawing view. I've run into those issues before in the past. Never figured out why.
