2 Replies Latest reply on Aug 16, 2014 9:01 AM by Yong Ning
    How to get Use named configurations In assembly, with API.
    Yong Ning
      In assembly, Use named configurations is p1.
      In Part1.sldprt, set configuration name is "p3".
      Help me.
      How to get Use named configurations (is p1) In assembly, .with API
          • Re: How to get Use named configurations In assembly, with API.
            Yong Ning
            Thanks for your reply
            'Change Referenced Configuration Example (VB)
            'This example shows how to change the configuration of a component in an assembly without opening the part.
            Option Explicit
                Dim swApp                   As SldWorks.SldWorks
                Dim swAssy                  As SldWorks.AssemblyDoc
                Dim swSelMgr                As SldWorks.SelectionMgr
                Dim swModel                 As SldWorks.ModelDoc
                Dim swComp                  As SldWorks.Component
                Dim RefCfg                  As String
                Dim oSwModel As ModelDoc2
                Set swModel = swApp.ActiveDoc
                Set swAssy = swModel
                Set swComp = swSelMgr.GetSelectedObject5(1)
                Debug.Print swComp.Name, swComp.Name2
                ' Debugging only
                RefCfg = swComp.ReferencedConfiguration
                Debug.Print RefCfg
                ' Change component config to "in-use"
                'swComp.ReferencedConfiguration = "p1" 'RefCfg
                Set oSwModel = swComp.GetModelDoc
                Debug.Print oSwModel.GetTitle
                oSwModel.ShowConfiguration RefCfg
                ' For changes to take effect
                swAssy.EditRebuild
            Private Sub ll()
              Dim oDic As New Dictionary, Str
              Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, oSwModel As ModelDoc2
                Set SwApp = GetObject(, "SldWorks.Application")
                Set SwModel = SwApp.ActiveDoc
              Dim SwSelMgr As SelectionMgr
                Set SwSelMgr = SwModel.SelectionManager
              Dim SwAssy As AssemblyDoc, SwComp As Component2
                Set SwAssy = SwModel
              Dim SwConf As Configuration, SwRootComp As Component2
                Set SwConf = SwModel.GetActiveConfiguration
                Set SwRootComp = SwConf.GetRootComponent
              Dim vChildComp
                vChildComp = SwRootComp.GetChildren
                For ii = 0 To UBound(vChildComp)
                   Set SwComp = vChildComp(ii)
                   Set oSwModel = SwComp.GetModelDoc
                   'Debug.Print ii, SwComp.Name, oSwModel.GetTitle
                   If Not oDic.Exists(oSwModel.GetTitle) Then
                      oDic(oSwModel.GetTitle) = ""
                      Str = SwComp.ReferencedConfiguration
                      Debug.Print ii, SwComp.Name, oSwModel.GetTitle, Str
                      oSwModel.ShowConfiguration Str
                Next ii
