When I open an IPS assembly which uses hardware from the metric library, the initial display is correct. But when the assembly finishes buiding, all of the hardware increases in size. Looks to be approxmately 2.54 times larger than it should be. It seems that the cm are not converting to inches. I can find no way to fix this.
I'm a PCB guy, a casual Solidworks user, dso forgive my ignorance if this is some simple setting I'm missing.
Pete
