2 Replies Latest reply on Jun 16, 2014 8:29 AM by Klaudiusz Skiba
    Surface Finish Number with Macro
    Klaudiusz Skiba
      Hi, I have another question about surface finishes on solidworks drawings. I need to gather all surface finish numbers. I need help with aquiring one, the rest I can do on my own. Thank you a lot. Also posting a picture showing what I need:
        • Re: Surface Finish Number with Macro
          Artem Taturevych
          Here is the macro to get all surface finish symbols from active drawing view. Macro outputs Minimum Roughness value to the Immidiate VBA window:
              Set swDraw = swApp.ActiveDoc
              Dim vSheets As Variant
              vSheets = swDraw.GetViews
              Dim i As Integer
              Dim j As Integer
              Dim k As Integer
              For i = 0 To UBound(vSheets)
                  Dim vViews As Variant
                  vViews = vSheets(i)
                  For j = 0 To UBound(vViews)
                      Dim swView As SldWorks.View
                      Set swView = vViews(i)
                      Dim vSfSymbs As Variant
                      vSfSymbs = swView.GetSFSymbols
                      If Not IsEmpty(vSfSymbs) Then
                          For k = 0 To UBound(vSfSymbs)
                              Dim swSfSymb As SldWorks.SFSymbol
                              Set swSfSymb = vSfSymbs(k)
                              Debug.Print swSfSymb.GetText(swSurfaceFinishSymbolText_e.swSFSymbolMinimumRoughness)
                          Next
                  Next
              Next
