My coworker and I are both stumped. We routinely use edrw to save our models out to the network for the machine shop. One one particular assembly model, some of the views are missing. All the balloons are there, but a couple of the images are missing, and only on sheets 1 & 2; the front model sheet is fine. Also the drawing looks perfectly fine in SolidWorks. We have tried fully resolving the model as suggested by the help file, and also forcing a rebuild. What else should we try?
We are on SW2013 sp 3.0 and EDrawings 2013.
Thank you.
OK, are you saving edrawing files from SW or do you open the files in edrawings and then save them as required.
If you're using SW to make edrawings, then can you try opening the files in edrawings and then saving out from there.
