5 Replies Latest reply on Jun 13, 2014 11:33 AM by Sanya Shmidt
    Boolean - how can it be both true and false at the same time??
    Michael Kohlmann
      Hey All,
      Maybe I don't know enough about VBA to understand this, but how can a boolean be both true and false at the same time??
      Looking at the code snippet below, bExportComplete is a boolean.
      It gets set to True by the default ITableAnnotations::SaveAsText member.
      But somehow manages to run both the True and "Not" True If statements??
      It both sends a message to the user, and deletes the BOM...
      If I manually set the bExportComplete to either True or False (using the commented out line), it works as it's suppose to.
      If I only use the return value from SaveAsText I end up running both... Does anyone know much about this function that could explain it?
      --Snippet---
      'Save Standard Table
      bExportComplete = swTableAnn.SaveAsText(CsvFileName, "~")
      Debug.Print (" --File Save Result is: " & bExportComplete)
      ' bExportComplete = False '(Debug Message/Delete)
      If Not bExportComplete Then
          Debug.Print ("Failed to Complete, send message to user? Why do both of these sections run????")
          Application.SldWorks.SendMsgToUser ("CSV File failed to save." & Chr(13) & Chr(10) & "Try a manual save-as of BOM in lower left corner.")
      If bExportComplete Then
          ' Delete BOM
          ' Convert BOM to Feature and Select it
          Debug.Print ("Deleting BOM ... ");
          StatusBarMsg ("Deleting BOM")
          Set swFeat = swBOMTable.BomFeature.GetFeature
          bRet = swFeat.Select2(False, 0)
          Debug.Print ("BOM Name/ID is: '" & swFeat.Name & "' / '" & swFeat.GetID & "' ... ");
          'And Delete
          swDoc.DeleteSelection (True)
          Debug.Print ("' completed")
      --EndSnippet---
      My Debug output looks as follows:
      --File Save Result is: True
      Deleting BOM ... BOM Name/ID is: 'Bill of Materials53' / '6235' ... ' completed
      It's mind boggling to me.
      Thanks in advance for any insight or clarification.
