0 Replies Latest reply on Oct 3, 2014 11:29 PM by Yong Ning
    How to get feature name (Configuration)?
    Yong Ning
          Dim swApp                                   As SldWorks.SldWorks
          Dim SwModel                                 As SldWorks.ModelDoc2
          Dim SwFeat                                  As SldWorks.Feature
          Set SwModel = swApp.ActiveDoc
          'Debug.Print "File = " & swModel.GetPathName
          Set SwFeat = SwModel.FirstFeature
          Do While Not SwFeat Is Nothing
            With SwFeat
              If .GetTypeName = "Reference" Then
                Debug.Print .Name, .GetTypeName
              Set SwFeat = SwFeat.GetNextFeature
            End With
          Loop
      code result is Part1-1
      help me , need result is Part-1→ (a2) (a4)  Configuration name
      Set Part = swApp.ActiveDoc
      Set SelMgr = Part.SelectionManager
      boolstatus = Part.Extension.SelectByID2("Part1-1@b", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
      Part.CompConfigProperties4 2, 0, True, True, "a4", False
      Part.ClearSelection2 True
      'Get Components in Drawing View Example (VB)
      'This example shows how to get the components in a drawing view.
      ' Preconditions:
      '         (1) Drawing document is open.
      '         (2) Drawing view is selected.
      ' Postconditions: None
      Option Explicit
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swDraw                      As SldWorks.DrawingDoc
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim swView                      As SldWorks.View
          Dim swRootDrawComp              As SldWorks.DrawingComponent
          Dim vDrawChildCompArr           As Variant
          Dim vDrawChildComp              As Variant
          Dim swDrawComp                  As SldWorks.DrawingComponent
          Dim swComp                      As SldWorks.Component2
          Dim swCompModel                 As SldWorks.ModelDoc2
          Dim i                           As Long, ss
          Dim bRet                        As Boolean
          Dim rootConf As Configuration
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          Set swView = swSelMgr.GetSelectedObject5(1)
          ss = swView.ReferencedConfiguration
          Stop
          Set swCompModel = swApp.GetOpenDocumentByName(swView.GetReferencedModelName)
          Debug.Print swCompModel.GetTitle
          Set rootConf = swCompModel.GetActiveConfiguration
          Debug.Print rootConf.Name
          Stop
          Set swRootDrawComp = swView.RootDrawingComponent
          Set swComp = swRootDrawComp.Component
          Debug.Print swComp.Name
          Debug.Print "  View = " & swView.Name
          vDrawChildCompArr = swRootDrawComp.GetChildren
          Set swDrawComp = vDrawChildCompArr(0)
          Debug.Print swDrawComp.Name
          Debug.Print swDrawComp.Component.Name
          Stop
          For Each vDrawChildComp In vDrawChildCompArr
              ' Returns NULL if underlying model is open in a different configuration
              Set swComp = swDrawComp.Component
              If Not Nothing Is swComp Then
                  ' Returns NULL if drawing is lightweight
                  Set swCompModel = swComp.GetModelDoc
                  Debug.Print " "
                  Debug.Print "      Component        = " & swComp.Name2
                  Debug.Print "      Configuration    = " & swComp.ReferencedConfiguration
                  If Not Nothing Is swCompModel Then
                      Debug.Print "      File             = " & swCompModel.GetPathName
                      Debug.Print " "
          Next
      Private Sub llll()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
          Set SwApp = Application.SldWorks
          Set SwModel = SwApp.ActiveDoc
          Debug.Print SwModel.GetTitle
          Set swSelMgr = SwModel.SelectionManager
        Dim SwComp As Component2, Str, SwFeat As Feature
          'Set SwComp = swSelMgr.GetSelectedObjectsComponent(1)
          'Debug.Print SwComp.Name2
          Str = "Part1-1"
          Set SwFeat = SwModel.FeatureByName(Str)
          Debug.Print SwFeat.Name
          Set SwComp = SwFeat.GetSpecificFeature
          Debug.Print SwComp.GetModelDoc.GetTitle
          Debug.Print SwComp.ReferencedConfiguration
        Dim oSwModel As ModelDoc2
          Set oSwModel = SwComp.GetModelDoc
          oSwModel.ShowConfiguration2 SwComp.ReferencedConfiguration
          Stop
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
        Dim SwSelMgr As SelectionMgr
          Set SwSelMgr = SwModel.SelectionManager
          SwModel.Extension.SelectByID2 "Bill of Materials2", "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0
        Dim SwBomFeat As BomFeature
          Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
        Dim Visible, Names
          Names = SwBomFeat.GetConfigurations(False, Visible)
          Names(2) = ""
          Names(1) = ""
          Names(3) = ""
          SwBomFeat.SetConfigurations True, Visible, Names
