I've created a STEP export from Proe WF4. The original file has some surfaces colored red to indicate to the molder what has changed. However, when it comes into SW 2013 the entire part is white. I see multiple colors listed under the DisplayManager tab and they correspond to my color preaks in proe, but each has the same color so you cannot see the difference on screen.
How can I make sure these colors come in as defined in the STEP file, or at least in different colors?
Doug,
When it is exported from ProE, make sure it is exporting to step version 214,
If it is 203, the colors not identified.
