2 Replies Latest reply on Jun 10, 2014 9:53 PM by Yong Ning
    How to traverse Configuration(s)
    Yong Ning
          • Re: How to traverse Configuration(s)
            Yong Ning
            Thanks your link web,the code is
            ' Forcibly rebuild each configuration
            Option Explicit
                Dim swApp                   As SldWorks.SldWorks
                Dim swModel                 As SldWorks.ModelDoc2
                Dim vConfNameArr            As Variant
                Dim sConfigName             As String
                Dim nStart                  As Single
                Dim i                       As Long
                Dim bShowConfig             As Boolean
                Dim bRebuild                As Boolean
                Dim bRet                    As Boolean
                Set swModel = swApp.ActiveDoc
                Debug.Print "File = " + swModel.GetPathName
                vConfNameArr = swModel.GetConfigurationNames
                For i = 0 To UBound(vConfNameArr)
                    sConfigName = vConfNameArr(i)
                    bShowConfig = swModel.ShowConfiguration2(sConfigName)
                    nStart = Timer
                    bRebuild = swModel.ForceRebuild3(False)
                    Debug.Print "  Config       = " & sConfigName
                    Debug.Print "    ShowConfig = " & bShowConfig
                    Debug.Print "    Rebuild    = " & bRebuild
                    Debug.Print "    Time       = " & Timer - nStart & " s"
                Next i
            Restult is
            File = F:\MyPrograme\BE(J)S\Part1.SLDPRT
              Config       = A1
                ShowConfig = False
                Rebuild    = True
                Time       = .1875 s
              Config       = A2
                ShowConfig = True
                Rebuild    = True
                Time       = .078125 s
              Config       = A3
                ShowConfig = True
                Rebuild    = True
                Time       = .078125 s
              Config       = A4
                ShowConfig = True
                Rebuild    = True
                Time       = .078125 s
            Sub Main1()
                Dim i                       As Long, Str
                Dim bRet                    As Boolean
                Dim swCustProp As CustomPropertyManager
                    Set swCustProp = swModel.Extension.CustomPropertyManager(sConfigName)
                    nStart = Timer
                    Str = "SW-Mass@@" & sConfigName & "@" & swModel.GetTitle
                    'Debug.Print """" & Str & """"
                    swCustProp.Set "质量", Chr(34) & Str & Chr(34)
                Next i
