Orientation of fittings in piping
Question asked by Laura Bishop on Jun 10, 2014
Latest reply on Sep 4, 2015 by Punya Gupta
I'm fairly new to routing and am trying to insert a fitting (valve/tee/etc) on to a split point on a pipe. I'm using drag and drop from the design library and using tab to change the orientation when the fitting is snapped to the right place. However, I only seem to be able to turn the fitting through 90degrees; it either sticks up in the air or at right angles to that when what I really need is for it be pointing downwards.
Can anyone tell me how to turn a fitting through 360degrees or at least line up the fitting to be correctly orientated when I drag and drop.
