2 Replies Latest reply on Jun 10, 2014 1:55 AM by Shekhar Erande
    Attaching Note or Balloon to Part Edge not Drwaing?
    Shekhar Erande
      Hello Experts,
      I have application where I would like to show some sort of Text when user select edge on the PART NOT drawing . Is it possible in Solidworks? if yes please guide me.
      I dont want to use Drawing view.
      thanks,
      shekhar
        • Re: Attaching Note or Balloon to Part Edge not Drwaing?
          Santosh Pawar
          Hi Shekhar,
          You can use the NewSelectionNotify event handler to achieve this functionality, the vba code for this would look something like this,
          Private Function msrcPartDoc_NewSelectionNotify() As Long
             ' todo: Check the type of entity selected for type Edge and proceed
              Dim myNote As Object
              Dim myAnnotation As Object
              Dim myTextFormat As Object
              Set myNote = part.InsertNote("123")
              If Not myNote Is Nothing Then
                 myNote.LockPosition = False
                 myNote.Angle = 0
                 boolstatus = myNote.SetBalloon(0, 0)
                 Set myAnnotation = myNote.GetAnnotation()
                 If Not myAnnotation Is Nothing Then
                    longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swBENT, 0, True, False, False, False)
                    boolstatus = myAnnotation.SetPosition(0.621186585097226, 0.522873399967693, -0.641407457091692)
                    boolstatus = myAnnotation.SetTextFormat(0, True, myTextFormat)
              part.ClearSelection2 True
              part.WindowRedraw
          End Function
              Shekhar Erande
              Thanks santosh!! This exactly what I was looking for
              Here is my code for C# users
                object myTextFormat = "";
                          ModelDoc2 modelDoc2 = SWApp.IActiveDoc2;
                          myNote = modelDoc2.InsertNote("12345");
                          Note myNote1 = myNote as Note;
                          if (null != myNote1)
                              myNote1.LockPosition = false;
                              myNote1.Angle = 0;
                              bool boolstatus = myNote1.SetBalloon(0, 0);
                              IAnnotation myAnnotation = myNote1.GetAnnotation() as IAnnotation;
                              if (null != myAnnotation)
                                   int longstatus = myAnnotation.SetLeader3((int)swLeaderStyle_e.swSTRAIGHT, 0, true, false, false, false);
                                  boolstatus = myAnnotation.SetPosition(x, y, z);
                                  boolstatus = myAnnotation.SetTextFormat(0, true, myTextFormat);
