2 Replies Latest reply on Jun 10, 2014 12:21 AM by Greg Rupp
    Example of DocEvents
    Greg Rupp
      Does anyone have any VB.net examples using DocEvents? I'm trying to figure out how to use DocEvents_FileSaveNotifyEventHandler for all three file types. Thanks!
        • Re: Example of DocEvents
          Artem Taturevych
          Check this code snippet. It is also suggested to unsubscribe from events once the object is not used:
          Dim swModel As ModelDoc2
          Public Sub main()
              swModel = swApp.ActiveDoc
              AttachHandler(swModel)
          Sub AttachHandler(ByVal model As ModelDoc2)
              If model IsNot Nothing Then
                  Select Case model.GetType
                      Case swDocumentTypes_e.swDocPART
                          Dim part As PartDoc = model
                          AddHandler part.FileSaveNotify, AddressOf OnFileSave
                      Case swDocumentTypes_e.swDocASSEMBLY
                          Dim assm As AssemblyDoc = model
                          AddHandler assm.FileSaveNotify, AddressOf OnFileSave
                      Case swDocumentTypes_e.swDocDRAWING
                          Dim drw As DrawingDoc = model
                          AddHandler drw.FileSaveNotify, AddressOf OnFileSave
                  End Select
          Function OnFileSave(ByVal FileName As String) As Integer
              MsgBox("File Saved: " + FileName)
              Return 0
          End Function
          Public swApp As SldWorks
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          LinkedIn - SolidWorks API Group
