0 Replies Latest reply on Jun 8, 2014 11:44 PM by Vishaldeep Singh
    i want to make two curves
    Vishaldeep Singh
      hello
      in the attachment there is excel file and macro file.
      there is a special symbol "$" in the  excel sheet and i want upto $ sign the curve1 with points in column 1,2,3 and 2nd curve with point in colummn 4,5,6 and after $ sign the curve should generate in curve 3 with points in column 1,2,3 and curve 4 with points in column 4,5,6.
      so my question is is this thing possible in macro coding. what will be the modification required.
      Dim swSketchMgr As SldWorks.SketchManager
      Dim swExcel As Excel.Application
      Dim exSheet As Excel.Worksheet
      Dim i As Integer
      Dim sVal As String
      Dim xpt As Double
      Dim ypt As Double
      Dim zpt As Double
          Set swModel = swApp.ActiveDoc
          Set swExcel = GetObject(, "Excel.Application")
          Set exSheet = swExcel.ActiveSheet
          Set swSketchMgr = swModel.SketchManager
      swModel.InsertCurveFileBegin
      i = 1
            Do While exSheet.Cells(i, 1).Value <> ""
              sVal = exSheet.Cells(i, 1).Value
              If sVal = "$" Then
                  swModel.InsertCurveFileEnd
                  swModel.ClearSelection2 True
              Else
              xpt = exSheet.Cells(i, 1).Value * 0.001
              ypt = exSheet.Cells(i, 2).Value * 0.001
              zpt = exSheet.Cells(i, 3).Value * 0.001
              boolstatus = swModel.InsertCurveFilePoint(xpt, ypt, zpt)
          i = i + 1
          Loop
          boolstatus = swModel.InsertCurveFileEnd
