As I run my simulation study (Static) and then save the information into the " trend Tracker " I find that if the system runs the study in 10 sec it takes 15 sec to save it on the trend tracker and if the system runs the study in 15 sec it takes 20 sec to save it on the trend tracker.
I have SW 2014 SP 3.0
So I would like to ask
- Is the time of the trend tracker should be <,>,= the simulation run time ?
- how can I reduce the time taken by the trend tracker ?
That's all and thank you in advance .
this is happening on all models? what happens with a really simple cantilever beam?
what is your exact workflow? every step in the process
did trend tracker ever work or is this your first time using it?
what do you want to use trend tracker for specifically?
