Hi
iam working on one of my undergraduate project which is actually related to a mechanical finger . i have designed my project but the most painfull part is creating a rope passing through a pipe should pull the finger
the cable should pull the triangular shaped part in the starting and pass on the red circular surface ( overlapping/concentric) then should pass through the pipe/hose
can any one help me with this problem ..
waiting for ur reply ...
thanks
you need to model it?
you need to animate it?
or you need to simulate it?
the reason i ask is that modeling is probably possible
animation and simulation will be difficult
there are no rope elements, you would need to use a force or break it down into almost like a chain
see the kb and the forum for further discussions about this and examples
