I am trying to create a sketch on a sheet metal part and basically there are two places that are the same on each side that need to be extended, it is sheet metal and the person working on it before me did some stuff that I do not know how to do so i am just going the easy route and extruding it. Hard to explain i can include a picture if needed. But every time i create a sketch on the surface it will not let me create drawings. The wierd thing is it did on the other half of the part but not this one. Thanks!
If you can attach your file here along with a picture describing what you need to do then someone might be able to look at it and suggest you the best way(s)
Please use "advanced editor" in case you want to attach any files.Click on reply and then click "use advanced editor".
