7 Replies Latest reply on Jun 27, 2017 9:02 AM by Chloe Xiao
    Helical spring design
    Rahul Yadav
      Dear All,
      I want to make Closedand squared ground helical compression spring. Can anyone suggest me procedure how to make it in solidwork 2012??
      I request you all to reply me as soon as possible because it is very urgent.
        • Re: Helical spring design
          Kelef Man
          hei'ya Rahul, welcome to the forum,
          see att-prt, to get you started,
          hope this helps- have a good'n kelef
              Rahul Yadav
              Dear Kelef,
              This is not my need. I want detail procedure how to design closed and ground end helical spring, if you know then help me but please don't reply with a spring snapshot. This snapshot cann't help anyone.
                  Deepak Gupta
                  Welcome to SOLIDWORKS forums Rahul.
                  Please be generous and check the attachment Kelef has shared before making any comments. He has added the snapshot to give you the quick glimpse of the file he has made.If that is not what you need then please add more details like size, pictures, links, etc.
                  You might also find this post helpful for your future reference.
                    J. Mather
                    Maybe this snapshot will help someone.
                    If  you click on the link to download the zip file.
                    Right click on the file and select Extract All
                    Then open the sldprt file
                    - you should be able to reverse engineer how the part was made from the feature tree.
                  Joseph Sensenig
                  Rahul,
                  For myself, still being fairly new to SW, I find that springs are rather complex geometries for beginners to design.  I have attached a spring generating macro that SW will run. It is a great timesaver. You can create compression, extension, spiral, and torsion springs, all using the same macro. Also, you can select different end types, as well as various shapes for the section profile.
                  (1) Download the attached file, and save it to your computer.
                  (2) Sketch a circle in a new part document to represent the diameter of your spring.
                  (3) Go to Tools- near the bottom of the list, click Macro, then select Run.
                  (4) Browse to your storage location of the file, select it, and open.
                  (5) The macro dialogue box will populate your feature manager, and you can fill in your options, just like a standard SW feature.
                  Hope this is helpful.
                    Kelef Man
                    hei'ya Rahul, sorry I've apparantley have misunderstood,
                    "anyone suggest me procedure how to make it in solidwork 2012??",
                    let's see if we can get you on with the project more positively-
                    you wish to "design" a closed end helical compression spring- ok
                    my pointers would be-starting with
                    Spring Materials
                    The selection of material is usually the first step in design.
                    Material can be based on tensile strength, temperatures,
                    elastic modulii, fatigue boundaries, corrosion, and not least of all-cost,
                    other factors than these will also need to be adhered to as in the design brief stipulations
                    samples may be:-HCSS - High-carbon spring steels as (ASTM A228),(ASTM A227)
                    High Tensile Hard Drawn (ASTM A679),Oil Tempered (ASTM A229),
                    Carbon Valve (ASTM A230)
                    your design brief may stipulate:-
                    Geometry - Length, Wire Diameter, Coil Diameter, Mass - you have none given
                    Material Data - Elastic Modulie, Poisson's Ratio, Density - you have none given
                    End Treatment - Closed and Ground- but no conditions thereof
                    required considerations for modeling/designing:-
                    primary spring geometric design parameters would be-
                    Free Length (Lo) - The length of uncompressed spring.
                    Wire Diameter (d) - The diameter of the wire
                    Coil Diameter (D) - The mean diameter of the helix, i.e., (D outer + D inner)/2.
                    Total Coils (Nt)- The number of coils or turns in your spring.
                    Active Coils (Na) - The number of coils that are live and compress
                    Solid Length (Ls) - The minimum length at full duress of the coils.
                    Pitch (p) - The distance from center to center of one revolution of live coil
                    Pitch Angle (a) - Angle between coils and base.
                    The angle would be calculated thru: a=arctan(p/(pi*D))
                    Geometric Notations and calculation-
                    Live Coils, =Na i.e. = Nt-2
                    Free Length, =Lo i.e.= Nap+2d
                    Solid Length, =Ls i.e.= (Na+2)d
                    Pitch, =p i.e.= (Lo-2d)/Na
                    (as in the att.prt I assumed one inactive coil at each end of the spring)
                    Outer Diameter (Do) -  Do=D+d - The outer diameter of the spring
                    Inner Diameter (Di) - Di=D-d - The inner diameter of the spring
                    Spring Index (C) - C=D/d - The ratio of mean coil diameter to wire diameter
                    beyond these there are  also e.g.:-
                    Wire Length (Lw) - The length needed for the spring. Lw=(pi*D)*((Na/cos(a))+Ni*a)
                    Spring Mass (M)
                    Natural Frequency (fn)
                    Maximum Load (Pmax) - full compression
                    Maximum Deflection (dmax) - to reach full compression
                    Spring Rate (k)- unit deflection
                    Slenderness Ratio (Lo / D)
                    Shear Modulus (G)
                    Uncorrected Maximum Shear Stress (tmax)
                    Corrected Maximum Shear Stress (tmax')
                    but I'm rambling now-
                    these will all, and more be required to define a final design,
                    that will have to adhere to the letter of the design brief-
                    I unfortunately have no experience in designing any type of springs
                    but please see the att.prt as a representation
                    you can change the global variables in the Equations folder
                    and hopefully this will be of some use to you
                    my apologies once again for misunderstanding you-   kelef
