11 Replies Latest reply on Jun 16, 2014 12:46 PM by Deepak Gupta
    Hide layer, print Drawing, close drawing w/o save
    Eric Fox
      Can anyone help to create a macro for drawing files that will check if a specific layer is visible, and if it is visible, hide the layer. Then I need to macro to print the drawing & close without saving.
      When our company creates a drawing package for our customers we provide a print for most of the sub-assemblies and top level assemblies within the system (typically around 200-300 drawings per customer). These prints need to be dimensionless. So, in all of our drawing templates I have created a layer named "Dimension" where all of the dimensions reside. I found exactly what I need to turn the layer on/off from the API help (see below), but I'm not sure how to incorporate the print and 'no save' portion of the macro.
      I have 0 programming experience, so I'm kind of lost here.
      Sample code:
      ' Preconditions:
      '          (1) Drawing document is open.
      '          (2) Drawing document contains a layer named Dimension.
      ' Postconditions:
      '          If Dimension layer is visible, then it becomes not visible.
      '             - or -
      '          If Dimension layer is not visible, then it becomes visible.
      Option Explicit
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swLayerMgr                  As SldWorks.LayerMgr
          Dim swLayer                     As SldWorks.Layer
          Set swModel = swApp.ActiveDoc
          Set swLayerMgr = swModel.GetLayerManager
          Set swLayer = swLayerMgr.GetLayer("Dimension")
          If swLayer.Visible = False Then
              ' Toggle layer on
              swLayer.Visible = True
              Debug.Assert True = swLayer.Visible
          Else
              ' Toggle layer off
              Debug.Assert False = swLayer.Visible
