0 Replies Latest reply on Jun 5, 2014 4:38 PM by Chris Johnson
    AlignWithView
    Chris Johnson
      Hello All,
      Im trying to loop through 4 pre-selected drawing views adding a "vertical alignment by center" to each view The 4th view as the baseview.
      the following code works for the first one but dies on the second one.
      WHAT IT SHOULD DO:
      Precondtions:
      1.) select 4ea drawing views (they should be stacked vertically one on top of the next)
      2.) the last view selected is the base view
      post conditions:
      all four views are aligned vertically by center
      WHAT IT IS ACTUALLY DOING:
      1.)the first view is aligned correctly
      2.) error message stating an object variable is not set because swview is empty
      I have no idea what im missing but its wearing on me!!
      here is my code
      Option Explicit
          Dim swApp                     As SldWorks.SldWorks
          Dim swModel                   As SldWorks.ModelDoc2
          Dim swSelMgr                  As SldWorks.SelectionMgr
          Dim swView                    As SldWorks.View
          Dim BoolStatus                As Boolean
          Dim BaseView                  As SldWorks.View
          Dim i                              As Integer
          Dim ViewCount                 As Double
          'Connect to Solidworks & active document
              Set swModel = swApp.ActiveDoc
          'get selected drawingview count
              ViewCount = swSelMgr.GetSelectedObjectCount2(-1)
          'define Baseview as the 4th view selected
              Set BaseView = swSelMgr.GetSelectedObject6(4, -1)
               For i = 1 To ViewCount
                  Set swView = swSelMgr.GetSelectedObject6(i, -1)
                  BoolStatus = swView.AlignWithView(swAlignViewTypes_e.swAlignViewVerticalCenter, BaseView)
              i = i + 1
              Debug.Print i
              Next i
      Thanks again !
      Chris
