When checking an assembly using the Interference detection I get some parts that end up inside another.
This shows up in red as a mm³ area.
What I would really like to see is how far (in mm) one part goes into another.
The only way I have found to get this dimension is to exit out of interference.
Then use the measure tool to get the size,
In this example it falls in 0.4 mm which for what we are doing would be ok.
Is there a way to set up the detection so rather than giving an area it could give a distance,
Mark
Mark not sure how the distance would be correct logically. Take a scenario where a part is interfering at an angle. In that case predicting the distance would not be easy.
