- I see a Fillet or Chamfer has a red-X error because one or more affected Edges no longer exists.
- I click Edit Feature. I want to reselect new edge(s) to be Filleted or Chamfered.
- under Items To Fillet/Chamfer I see the green ***Missing Edge*** item.
- I click the ***Missing Edge*** item
- press delete key to remove it. No response!
- click the Missing Edge a SECOND time
- press delete key. Now the missing edge goes away.
- click other edges in the model to add them to the Items To Fillet/Chamfer list.
This seems like a bug. Why do I have to click the item TWICE before I can delete it from the list? Any other program and I could click it once to select it and that's all it takes.
You actually don't need to delete it at all. If you just select the new edges and OK out of it it will tell you it is deleting the missing edges, and you just click ok.
