I am importing sketch points from excel using the macro however points that are close to each other are snapping to horizontal or vertically alignment depending on the level of zoom when the marco is run. I think I need to use the I.Sketch.Manager::SetAddtoDB function but I am not sure on the syntax to achieve this.
Thanks in advance for your help
Option Explicit
Dim Part As SldWorks.ModelDoc2
Dim Excel As Object
Dim i As Integer
Dim xpt As Double
Dim ypt As Double
Dim zpt As Double
Set Part = swApp.ActiveDoc
Set Excel = GetObject(, "Excel.Application")
Part.SketchManager.InsertSketch True
i = 1
Do While Excel.Cells(i, 1) <> ""
xpt = Excel.Cells(i, 1) / 1000
ypt = Excel.Cells(i, 2) / 1000
zpt = Excel.Cells(i, 3) / 1000
Part.CreatePoint2 xpt, ypt, zpt
i = i + 1
Loop
