These profiles are available right here:
I work with Bosch products on a daily basis.
One quick note though: the profiles you will find online are not 100% perfect (ie. symmetrical). They might be off by as little as .000001mm. The consequence is that when you go to create your cutlist, SW will not group weldments together because, though you might think they are identical, they are not (albeit by a very small amount).
I haven't had time to look into it, but a quick Google search found this: http://www13.boschrexroth-us.com/partstream/. Have you seen it?
