1 Reply Latest reply on Jun 5, 2014 1:00 AM by Deepak Gupta
    Older macro new SW
    george trott
      I have had this macro that another guy wrote for a while. It has worked thru every upgrade till now. Basicly what the process is, select a part or parts from an assembly (either from the tree or in the view window), then click the macro button and what it is supose to do is create a drawing from my desired drawing templates with front, left, right, and iso views, Use the dims set for drawing, insert a defined bom for the part and save the drawing. If a drawing exist then a window will pop up that says drawing exist use existing drawing, yes/no? It works fine in 2013 but it is not working in 2014. the code is below. I have changed the bold lines to my current search paths for the drawing template and BOM template, and the underlined line is where I am having the issues
      Option Explicit
      Dim Part As SldWorks.ModelDoc2
      Dim SELMGR As SldWorks.SelectionMgr
      Dim swView As SldWorks.View
      Dim swdrawing As SldWorks.DrawingDoc
      Dim swBOMAnnotation As SldWorks.BomTableAnnotation
      Dim swBOMFeature As SldWorks.BomFeature
      Dim boolstatus As Boolean
      Dim myView As SldWorks.View
      Dim partpath As String
      Dim VIEWMODEL As String
      Dim ERRORS As Long
      Dim WARNINGS As Long
      Dim vscale As Variant
      Dim swsheet As SldWorks.Sheet
      Dim fso
      Dim pathc As Object
      Dim titlec As Object
      Dim swasm As SldWorks.ModelDoc2
      Dim swcomp As SldWorks.Component2
      Dim i As Integer
      Dim asyp As SldWorks.ModelDoc2
      Dim vannotations
      Sub main(partpath As String)
      Set fso = CreateObject("Scripting.FileSystemObject")
      If fso.FileExists(Replace(UCase(partpath), ".SLDPRT", ".SLDDRW")) Then 'check to see if a drawing already exists in the same location as the part
      MsgBox "A File With This Name Already Exists In The Folder With This Part" + Chr(13) + "Fill Will Be Opened", vbOKOnly + vbExclamation, "STOP"
      swApp.OpenDoc6 Replace(UCase(partpath), ".SLDPRT", ".SLDDRW"), swDocDRAWING, swOpenDocOptions_LoadModel, "", ERRORS, WARNINGS
      Else
      'CREATE DRAWING
      Set Part = swApp.NewDocument("C:\Users\georget\Desktop\000-The great folder\0-USER RESOURCES\DRAWING\BARR PRT A", 12, 0.2159, 0.2794) 'CREATE NEW DRAWING WITH DRAWING TEMPLATE
      Set myView = Part.CreateDrawViewFromModelView3(partpath, "*Front", 0.075, 0.075, 0) 'INSERT VIEW
      'ADD PROJECTED VIEWS
      boolstatus = Part.ActivateView("Drawing View1")
      Set myView = Part.CreateUnfoldedViewAt3(0.15, 0.075, 0, False)
      'Part.ClearSelection2 True
      boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0.1131746427027, 0.1133066540541, 0, False, 0, Nothing, 0)
      Set myView = Part.CreateUnfoldedViewAt3(0.075, 0.15, 0, False)
      Set myView = Part.CreateUnfoldedViewAt3(0.15, 0.15, 0, False)
      vannotations = Part.InsertModelAnnotations3(0, 1212424, True, False, False, False) 'ADD ANNOTATIONS TO ALL VIEWS
      Set swdrawing = swApp.ActiveDoc 'get drawing
      boolstatus = swdrawing.ActivateView("Drawing View1") 'activate view
      Set swView = swdrawing.ActiveDrawingView 'get drawing view
      swView.SetDisplayMode3 False, swHIDDEN_GREYED, False, True 'SET HLV
      boolstatus = swdrawing.ActivateView("Drawing View4") 'activate view
      swView.SetDisplayMode3 False, swHIDDEN, False, True 'SET HLV
      ' 'not used
      Set swBOMAnnotation = swView.InsertBomTable3(True, 0.4, 0.3, swBOMConfigurationAnchor_TopRight, swBomType_PartsOnly, "", "C:\Users\georget\Desktop\000-The great folder\0-USER RESOURCES\DRAWING\BOM BARR PART", False) 'INSERT BOM ANCHORED
      Set swBOMFeature = swBOMAnnotation.BomFeature 'not shure
      vscale = swView.ScaleRatio 'get view scale
      Set swsheet = swdrawing.GetCurrentSheet 'get sheet
      swsheet.SetScale vscale(0), vscale(1), True, False 'set sheet to view scale
      swView.UseSheetScale = True 'set view to sheet scale
      Set Part = swApp.ActiveDoc 'get active part
      Part.Extension.SaveAs Replace(UCase(partpath), ".SLDPRT", ".SLDDRW"), swSaveAsCurrentVersion, swSaveAsOptions_SaveReferenced, Nothing, ERRORS, WARNINGS 'SAVE
      'End If
      Sub MAIN2()
      Set swasm = swApp.ActiveDoc
      Set SELMGR = swasm.SelectionManager
      'loop through selected components
      For i = 1 To SELMGR.GetSelectedObjectCount2(-1)
          Set swcomp = SELMGR.GetSelectedObjectsComponent3(i, -1) 'get first component
          Set asyp = swcomp.GetModelDoc2
          main (swcomp.GetPathName) 'send pathname to main
      '    main (asyp.GetPathName)
      Next i
      Sub MAIN3()
      partpath = swasm.GetPathName
      If fso.FileExists(Replace(UCase(partpath), ".SLDASM", ".SLDDRW")) Then 'check to see if a drawing already exists in the same location as the part
      swApp.OpenDoc6 Replace(UCase(partpath), ".SLDASM", ".SLDDRW"), swDocDRAWING, swOpenDocOptions_LoadModel, "", ERRORS, WARNINGS
      Else
      'CREATE DRAWING
      Part.Extension.SaveAs Replace(UCase(partpath), ".SLDASM", ".SLDDRW"), swSaveAsCurrentVersion, swSaveAsOptions_SaveReferenced, Nothing, ERRORS, WARNINGS 'SAVE
      'End If
      Please help.
        • Re: Older macro new SW
          Deepak Gupta
          Looks like you have missed out the extensions in these lines when changing the paths.
          'CREATE DRAWING
          Set Part = swApp.NewDocument("C:\Users\georget\Desktop\000-The great folder\0-USER RESOURCES\DRAWING\BARR PRT A.drwdot", 12, 0.2159, 0.2794) 'CREATE NEW DRAWING WITH DRAWING TEMPLATE
          Set swBOMAnnotation = swView.InsertBomTable3(True, 0.4, 0.3, swBOMConfigurationAnchor_TopRight, swBomType_PartsOnly, "", "C:\Users\georget\Desktop\000-The great folder\0-USER RESOURCES\DRAWING\BOM BARR PART.sldbomtbt", False) 'INSERT BOM ANCHORED
