2 Replies Latest reply on Jun 5, 2014 2:56 AM by Ar K
    Battle of InsertScale and SaveAs3 !!
    Ar K
      Hi :-)
      why in program 2, stl file can not Create but in program 1 stl file create well ? !!!!!!!!
      I need to, first doing scale then doing save as stl format.
      please help me :-)
      '1111111111111111111111111111111111111111111111111111111111111111111
      Dim swApp As Object
      Dim doc As ModelDoc2
      Dim swFeat As Feature
      Dim strFileName As String
      Set doc = swApp.ActiveDoc
      strFileName = doc.GetTitle
      longstatus = doc.SaveAs3("C:\temp\" & strFileName & "StlFormat.STL", 0, 0)
      Set swFeat = doc.FeatureManager.InsertScale(0, False, 1.01, 1.02, 1.03)
      '2222222222222222222222222222222222222222222222222222222222222222222
      Dim swApp As Object
        • Re: Battle of InsertScale and SaveAs3 !!
          Deepak Gupta
          Try these codes:
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc2
              Dim swFeatMgr               As SldWorks.FeatureManager
              Dim swScaleFeat             As SldWorks.Feature
              Dim swScale                 As SldWorks.ScaleFeatureData
              Dim sFileName               As String
              Set swModel = swApp.ActiveDoc
              Set swFeatMgr = swModel.FeatureManager
              sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
              sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
              sFileName = "C:\temp\" & sFileName & " StlFormat.STL"
              Set swScaleFeat = swFeatMgr.InsertScale(swScaleAboutCentroid, False, 1.01, 1.02, 1.03)
              swModel.ClearSelection2 True
              swModel.SaveAs3 sFileName, 0, 0
          The reason program 2 doesn't work for you is because scale feature is still selected and hence STL export fails. Once you clear that STL export works fine.
