Is there a way to have the terminal blocks Marked with the wire mark that is attached to it? When our panels are made we have the terminals marked with the wire that is in it. This way when wiring you just have to match up the wire with the terminal with the same mark on it.
Thank you for any help.
Peter Brennen
You need to replace the #short tag attribute used in the terminal symbol you use to the "#P_EQ_0" one found in the connection point attributes
