10 Replies Latest reply on Jun 4, 2014 4:00 PM by Adam Hoffman
    How to get if a selected component is transparent or not in vba
    Adam Hoffman
      Hello, I'm wondering how to get whether a selected component is transparent or not. I looked in the Api help and the display state example was a little out of my league. I was wondering how this could be done. I don't need any other info on the display state, just if it's transparent or not. Any help would be appreciated. Thanks.
        • Re: How to get if a selected component is transparent or not in vba
          Matt Martens
          Use the selection manager to get the IComponent2 object of the selected component. Then try IComponent2::GetRenderMaterials and IRenderMaterial::Transparency. I'm not sure if this will get the part level or component level transparency.
              Adam Hoffman
              Thanks for the tip, but the value returned from the component level transparency is zero no matter if the component is tranparent or not.
                  Matt Martens
                  Apparently, it returns the part level transparency. To verify this, open the part and change it to transparent and then try again. If the macro returns anything other than 0, then this is the case.
                  In the meantime, I will look elsewhere.
                      Adam Hoffman
                      I changed the part to transparent and it still returned zero.
                          Matt Martens
                          I got it. Use IComponent2::GetMaterialPropertyValues2. This will return an array of doubles. The value you are looking for is the 8th one so the array index would be 7. Any double value in any of the array values of -1 indicates that the component level has not been set. So if you check for a value of -1 of the 8th array object you will know if the part is transparent or not.
                              Adam Hoffman
                              I keep getting a type mismatch when I try to get the array of doubles:
                              Dim swAssembly As SldWorks.AssemblyDoc
                              Dim boolstatus As Boolean
                              Dim varMatProp As Variant
                              Dim TValue As Double
                              Set swApp = _
                              Application.SldWorks
                              Set swModel = swApp.ActiveDoc
                              Dim ModelType As Integer
                              ModelType = swModel.GetType()
                              If ModelType = swDocumentTypes_e.swDocASSEMBLY Then
                              Set swAssembly = swModel
                              Else
                              MsgBox ("You Must Have An Assembly Document Open To Run This Macro")
                              Exit Sub
                              Dim swEnt As SldWorks.Entity
                              Set swEnt = swSelMgr.GetSelectedObject5(1)
                              If swEnt Is Nothing Then
                              MsgBox ("No Entity Selected!")
                              Exit Sub
                              Set swComp = swEnt.GetComponent
                              If swComp Is Nothing Then
                              MsgBox ("No Component Selected, Try Again!")
                              Exit Sub
                              'RIGHT HERE IS MY ERROR
                              Set varMatProp = swComp.GetMaterialPropertyValues2(swInConfigurationOpts_e.swThisConfiguration, Nothing)
                              If Not varMatPropArray Is Nothing Then
                              TValue = varMatProp(7)
                              MsgBox (CStr(TValue))
                              I've tried a few different things and can't get it to work. Basically all I need it to do is to toggle the transparency on and off like this:
                              If selectedcomponent.IsTransparent Then
                              boolstatus = swAssembly.SetComponentTransparent(False)
                              Else
                              boolstatus = swAssembly.SetComponentTransparent(True)
                                  Matt Martens
                                  Don't use the Set at the beginning of the line. The variable varMatProp is not an object so you don't need set.
                                  The next line will now show an error because this is not a method to check if an array has values. Use "If UBound(varMatProp) > LBound(varMatProp) Then" instead.
                                      Adam Hoffman
                                      Thanks, I'm still a beginner at programming and started learning in VB.Net using Visual Studio 2013 Express. So alot of VB6 language still eludes me, because I never use it. But I figured writing this one in a .swp file would suffice.The tip you gave me ended up working great, Thanks!!! Here is what I ended up with for the transparency issue:
                                      If TValue = 0.75 Then
                                      ElseIf TValue = -1 Then
                                      swModel.ClearSelection2 True
                                      I've got it programmed to a button on my 3D Mouse now and it's amazing just how much time it saves when checking large assemblies. Thanks again!
