7 Replies Latest reply on Mar 31, 2017 11:39 AM by Deepak Gupta
    SolidWorks VBA - check if a "View" exists on a drawing
    Darren Smith
      Can anybody help???
      Say that I have a blank drawing (SLDDRW) open containing no views at (it is a completely blank sheet)
      How can I check, using a VBA macro, if no drawing views are on the sheet as I need this for part of a much larger macro.
      Many thanks in advance!!!!
      Darren
        • Re: SolidWorks VBA - check if a "View" exists on a drawing
          Deepak Gupta
          Option Explicit
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc2
              Dim swDraw                  As SldWorks.DrawingDoc
              Dim viewCount               As Long
              Set swModel = swApp.ActiveDoc
              Set swDraw = swModel
              viewCount = swDraw.GetViewCount
                  If viewCount = 1 Then
                          MsgBox "No Views Found On This Drawing!!"
              Xavier Rodríguez Nieto
              What happens if you have a multiple sheets drawing? How can you know if there is any view in an specific sheet?
              For instance: 2 sheets, sheet #1 has 0 views and sheet #2 has 3 views. How can you know the number of views in sheet #1? "GetViewCount" would return 5.
              I've tried with "ISheet:GetViews", but the thing is that this method returns an array even if there is no view in the drawing sheet. This array contains, in my case, 10 "standard orientations" like "Front", "Back" and so on.
                  Deepak Gupta
                  You can traverse thru each sheet and get the view count.
                      I don't think so, as in each sheet I will always get the same result, the "ISheet:GetViews" returns the view in the whole drawing (in my example I will always get "5").
                      However, I found this code example in the forum that solved it out with "GetFirstView" and "GetNextView" from IView:
                      Option Explicit
                      Dim swDrawing  As SldWorks.DrawingDoc
                      Dim swView      As SldWorks.View
                      Dim Errors      As Long
                      ' Is document active?
                      If swModel Is Nothing Then
                      swApp.SendMsgToUser2 "A Drawing file must be open.", swMbWarning, swMbOk
                      Exit Sub
                      ' Is it a part document?
                      If swModel.GetType <> SwConst.swDocDRAWING Then
                      Exit Sub
                      Set swDrawing = swModel
                      Set swView = swDrawing.GetFirstView
                      Set swView = swView.GetNextView
                      If swView Is Nothing Then
                      MsgBox "Please insert a Model View first!"
                      End
                      Else
                      swApp.ActivateDoc3 swView.GetReferencedModelName, False, swRebuildOnActivation_e.swUserDecision, Errors
                          Deepak Gupta
                          Not using ViewCount but traversing thru views on each sheet only using GetFirstView/GetNextView and get the count of i.
                          What end result you're looking for with view count?
                            Deepak Gupta
                            Here is what I mean
                            Option Explicit
                            Dim vSheets As Variant
                            Dim i As Integer
                            Dim j As Integer
                                vSheets = swDraw.GetSheetNames
                                For i = 1 To swDraw.GetSheetCount
                                    swDraw.ActivateSheet vSheets(i - 1)
                                    Set swView = swDraw.GetFirstView
                                        j = 0
                                        Do While Not swView Is Nothing
                                        j = j + 1
                                        Loop
                                        Debug.Print "View count on Sheet " & i & " is " & j
                                Next i
