6 Replies Latest reply on Jun 4, 2014 4:03 AM by Ar K
    Problem with "CreateSaveBodyFeature"
    Ar K
      hi :-)
      I created a vb.net version of macro as in
      http://help.solidworks.com/2014/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.IFeatureManager~CreateSaveBodyFeature.html
      My vb.net macro is not working but vba macro is working.
      ' VB.NET
      ' Preconditions: Part document is open and contains a solid body that has been split.
      ' Postconditions: C:\temp\p1.sldprt, C:\temp\p2.sldprt,C:\temp\p3.sldprt,
      ' and C:\temp\asm.sldasm are created.
      Imports SolidWorks.Interop.sldworks
      Partial Class SolidWorksMacro
          Public swModel As ModelDoc2
          Public swFeat As Feature
          Public swFeatMgr As FeatureManager
          Public swBodyFolder As BodyFolder
          Public bodyListVar As Object
          Public fileNames(2) As String
          Public fileNameVar As Object
          Public Sub main()
              swModel = swApp.ActiveDoc
              swFeat = swModel.FirstFeature
              swFeatMgr = swModel.FeatureManager
              Dim contLoop As Boolean = True
              Dim Name As String
              While Not swFeat Is Nothing And contLoop = True
                  Name = swFeat.GetTypeName2
                  If (Name = "SolidBodyFolder") Then
                      swBodyFolder = swFeat.GetSpecificFeature2
                      bodyListVar = swBodyFolder.GetBodies
                      contLoop = False
                  ElseIf (contLoop = True) Then
                      swFeat = swFeat.GetNextFeature
              End While
              fileNames(0) = "C:\temp\p1.sldprt"
              fileNames(1) = "C:\temp\p2.sldprt"
              fileNames(2) = "C:\temp\p3.sldprt"
              fileNameVar = fileNames
              swFeatMgr.CreateSaveBodyFeature(bodyListVar, fileNameVar, "C:\temp\ass.sldasm", True, True)
          Public swApp As SldWorks
      End Class
      Message was edited by: Ar K
        • Re: Problem with "CreateSaveBodyFeature"
          Artem Taturevych
          Try to use early binding, i.e. declare
          Dim bodyListVar(2) As Body2
          You may need to reassign the elements of the array because swBodyFolder.GetBodies may not cast directly to array of Body2(). Also make sure that you have 3 bodies in the folder, i.e. the size of the array is 3.
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Ar K
              Thank You Artem Taturevych :-)
              but i am sure that i have 3 bodies in the folder , and i should not cast object to body2 because:
              1-Function GetBodies() As System.Object
              2-Function CreateSaveBodyFeature( _
                 ByVal Bodies As System.Object, _
                 ByVal FilePaths As System.Object, _
                 ByVal AssemName As System.String, _
                 ByVal ConsumeBody As System.Boolean, _
                 ByVal CopyCustomProperty As System.Boolean _
              ) As System.Object
                Ar K
                I have correct vba code , and this code working excellent !!
                Please see this :
                Option Explicit
                Dim swFeat As SldWorks.Feature
                Dim swFeatMgr As SldWorks.FeatureManager
                Dim swBodyFolder As SldWorks.BodyFolder
                Dim bodyListVar As Variant
                Dim fileNames(2) As String
                Dim fileNameVar As Variant
                Set swModel = swApp.ActiveDoc
                Set swFeat = swModel.FirstFeature
                Set swFeatMgr = swModel.FeatureManager
                Dim contLoop As Boolean= True
                Dim Name As String
                        Set swBodyFolder = swFeat.GetSpecificFeature2
                        contLoop = False
                        Set swFeat = swFeat.GetNextFeature
                Wend
                swFeatMgr.CreateSaveBodyFeature bodyListVar, fileNameVar, "C:\temp\asm.sldasm", True, True
                But i have Problem with My VB.NET Code , There is no Error but don't work True !
                Please see this :
                    Public Sub main()
                        Dim Name As String
                                contLoop = False
                        End While
                End Class
                Ar K
                Please help me :-)
