4 Replies Latest reply on Jun 4, 2014 4:49 PM by Chris Johnson
    Reposition Drawing Views based on user selection
    Chris Johnson
      I'm revisiting an abandoned idea for a macro that will reposition pre-selected drawing views based on the order that the user selected them.
      The first view selected is the top view.
      The second view selected is the bottom view.
      The remaining views selected are the views that are to be repositioned evenly between the top and bottom views. The top & bottom views are not moved.
      In other words if you had 4 drawing views selected and the top view was 6” above the bottom view, then the middle views would be repositioned so that all 4 views are 2” apart.
      My problem is I have no idea how to traverse only through the selected views in order to get their positions and then reposition  as needed.
      Get first view & get next view dont seem applicable in this situation.
      How would you guys do this?
      Thank you!
      Chris
        • Re: Reposition Drawing Views based on user selection
          Artem Taturevych
          You need to loop through the selected object from 1 to SelectionMgr::GetSelectedObjectCount2. Then you can get the pointer either using the SelectionMgr::GetSelectedObject6 or SelectionMgr::GetSelectedObjectsDrawingView2. to allow users selected any entity from the view. Check the 'Selection Lists (VBA)' example in API Help for a sample code.
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
            Chris Johnson
            Thanks Artem,
            That got the ball rolling. Im well on my way now!
            Chris
                Chris Johnson
                Artem,
                here is a sample of what im trying to do. it mostly works but im getting unexpected results and I have no idea why.
                Preconditions:
                1.) CTRL Select drawing views in this order; topview, bottomview & then middleview
                2.) run macro
                DESIRED post conditions:
                1.) middle view moves midway between the top and bottom views
                2.) top and bottom views remain unmoved
                Actual post conditions:
                1.) middle AND Top views move up instead of middle view moving to the midway point
                do you see what im doing wrong?
                Thank you!
                Chris
                  Sub Main()
                    Dim swApp                     As SldWorks.SldWorks
                    Dim swModel                   As SldWorks.ModelDoc2
                    Dim swSelMgr                  As SldWorks.SelectionMgr
                    Dim swView                    As SldWorks.View
                    Dim TopView                   As Variant
                    Dim BottomView                As Variant
                    Dim MiddleView                As Variant
                    Dim Distance                  As Double
                    Dim spacing                   As Double
                    'Connect to Solidworks & active document
                        Set swModel = swApp.ActiveDoc
                    'Get TopView pos
                        Set swView = swSelMgr.GetSelectedObject6(1, -1)
                            TopView = swView.Position
                    'Get BottomView pos
                        Set swView = swSelMgr.GetSelectedObject6(2, -1)
                            BottomView = swView.Position
                        Set swView = Nothing
                    'Reposition Middle View
                        Set swView = swSelMgr.GetSelectedObject6(3, -1)
                            Distance = TopView(1) - BottomView(1)
                            spacing = Distance / 2
                            MiddleView = swView.Position
                            MiddleView(1) = TopView(1) - spacing
                            swView.Position = MiddleView
                        swModel.EditRebuild3
                    Set swApp = Nothing
