to save a lot of time, I decided to use the toolbox to generate gears (spur and bevel gears); then I need to modify them (cut holes, add a clamp embedded in the gear's bore, etc.).
When I try to add features to the gear, an error message appears, and something in the tree becames red. It's correlated with equation fails.
Is it possible to convert an equation-driven part, to a common one? I'm talking about removing the equations and variables, and put fixed values in quotation and features, but not manually.
Please tell me, otherwise I will choose to manually draw each gear instead of using the toolbox.
Thanks to all
RRZ
For a normal part you can right-click on the Equations folder at the top of the tree, choose "Manage Equations", then delete the equations from the equations dialog box. I assume this will work similarly with Toolbox parts, but I'm not sure.
