7 Replies Latest reply on Jun 4, 2014 8:29 AM by Nick Hayman
    Save face as dxf / Dwg
    Nick Hayman
      To save a dxf / dwg of a part you would normally right click on the face of the part and click export to dxf / dwg. Then choose sheet metal and then i would click the bend lines, keeping geometry as selected. Then click save on the pop up window.
      All this takes a lot of time if you have a few hundred to create!
      All i want to do is select the face and click a macro button or a shortcut ket back to the macro button.
      Must have been done before... any help welcome.
      Many thanks
      Nick
        • Re: Save face as dxf / Dwg
          Nick Hayman
          I found this code on the forum but it doesnt work for me... how do i get this to work? It also seems very complicated for just exporting a DXF. It must be doing somthing else?
          Many Thanks
          Nick
          Option Explicit
          Sub SelectFrontFace()
              Dim swApp                               As SldWorks.SldWorks
              Dim swMathUtility                     As SldWorks.MathUtility
              Dim swRefPlaneTransform     As SldWorks.MathTransform
              Dim swNormalVector          As SldWorks.MathVector
              Dim faceNormalVector        As SldWorks.MathVector
              Dim swNormalVectorRefPlane  As SldWorks.MathVector
              Dim swParallelCheck         As SldWorks.MathVector
              Dim swOriginPoint           As SldWorks.MathPoint
              Dim swOriginPointRefPlane   As SldWorks.MathPoint
              Dim swModel                 As SldWorks.ModelDoc2
              Dim swPart                  As SldWorks.PartDoc
              Dim swBody                  As SldWorks.Body2
              Dim swSelMgr                As SldWorks.SelectionMgr
              Dim swFeature               As SldWorks.Feature
              Dim subFeature              As SldWorks.Feature
              Dim NextFeature             As SldWorks.Feature
              Dim swPlane                 As SldWorks.Feature
              Dim PlaneFeature            As SldWorks.Feature
              Dim mySurface               As SldWorks.Surface
              Dim FeatureData             As SldWorks.WizardHoleFeatureData2
              Dim refPlane                As SldWorks.refPlane
              Dim myFace                  As SldWorks.Face2
              Dim myEdge                  As SldWorks.Edge
              Dim goodEdge                As SldWorks.Edge
              Dim swSketch                As SldWorks.Sketch
              Dim HoleDim                 As SldWorks.Dimension
              Dim vConfNameArr            As Variant
              Dim vDimVal                 As Variant
              Dim HoleSize                As Variant
              Dim varAlignment            As Variant
              Dim varViews                As Variant
              Dim swFaceVar               As Variant
              Dim vEdges                  As Variant
              Dim vP1                     As Variant
              Dim vP2                     As Variant
              Dim swBodyVar               As Variant
              Dim planeParams             As Variant
              Dim vFaceNorm               As Variant
              Dim vPointData              As Variant
              Dim vVectorData             As Variant
              Dim FeatureCount            As Long
              Dim FastenerType            As Long
              Dim swNameSize              As Long
              Dim swPathSize              As Long
              Dim FeatureType             As String
              Dim swConfigName            As String
              Dim NextFeatureType         As String
              Dim sketchName              As String
              Dim FastenerSize            As String
              Dim swModelName             As String
              Dim swPathName              As String
              Dim dataViews(0)            As String
              Dim swFileName              As String
              Dim swFileNameNoExtension   As String
              Dim swPathNoExtension       As String
              Dim swNewFilePath           As String
              Dim swNewFileName           As String
              Dim refPlaneName            As String
              Dim dataAlignment(11)       As Double
              Dim dDist                   As Double
              Dim aPointData(2)           As Double
              Dim aVectorData(2)          As Double
              Dim VectorLength            As Double
              Dim i                       As Integer
              Dim j                       As Integer
              Dim faceCount               As Integer
              Dim edgeCount               As Integer
              Dim HoleType                As Integer
              Dim MyPlane                 As Object
              Dim FrontPlane              As Object
              Dim boolstatus              As Boolean
              Dim bShowConfig             As Boolean
              Dim bCoin                   As Boolean
              Dim surf                    As Boolean
              Set swMathUtility = swApp.GetMathUtility
              Set swModel = swApp.ActiveDoc
              Set swPart = swModel
              Set swFeature = swPart.FirstFeature
              swModel.ClearSelection2 True
              vConfNameArr = swModel.GetConfigurationNames
              If UBound(vConfNameArr) > 0 Then
                      swConfigName = vConfNameArr(1)
                  ElseIf UBound(vConfNameArr) > 1 Then
                      MsgBox ("Too Many Configurations")
                  Exit Sub
                  Else
                      swConfigName = "Default"
              bShowConfig = swModel.ShowConfiguration2(swConfigName)
              Set PlaneFeature = swPart.FeatureByName("FRONT")
              refPlaneName = PlaneFeature.Name
              Set refPlane = PlaneFeature.GetSpecificFeature2
              Set swRefPlaneTransform = refPlane.Transform
              aPointData(0) = 0#
              aPointData(1) = 0#
              aPointData(2) = 1#
              vPointData = aPointData
              Set swOriginPoint = swMathUtility.CreatePoint(vPointData)
              Set swOriginPointRefPlane = swOriginPoint.MultiplyTransform(swRefPlaneTransform)
              vPointData = swOriginPointRefPlane.ArrayData
              aVectorData(0) = 0#
              aVectorData(1) = 0#
              aVectorData(2) = 1#
              vVectorData = aVectorData
              Set swNormalVector = swMathUtility.CreateVector(vVectorData)
              Set swNormalVectorRefPlane = swNormalVector.MultiplyTransform(swRefPlaneTransform)
              vVectorData = swNormalVectorRefPlane.ArrayData
              boolstatus = swPart.Extension.SelectByID2("FRONT", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
              Set MyPlane = swSelMgr.GetSelectedObject6(1, -1)
              swModel.ClearSelection2 True 'Add this code to clear all selection
              swBodyVar = swPart.GetBodies2(swSolidBody, False)
              Set swBody = swBodyVar(0)
              swFaceVar = swBody.GetFaces
              For faceCount = 0 To UBound(swFaceVar)
                  Set myFace = swFaceVar(faceCount)
                  bCoin = True
                  vEdges = myFace.GetEdges
                  dDist = swModel.ClosestDistance(MyPlane, myFace, vP1, vP2)
                      If dDist > 0 Then
                          bCoin = False
                  Set mySurface = myFace.GetSurface
                  surf = mySurface.IsPlane
                  planeParams = mySurface.planeParams
                  vFaceNorm = myFace.Normal
                  Set faceNormalVector = swMathUtility.CreateVector(vFaceNorm)
                  Set swParallelCheck = swNormalVectorRefPlane.Cross(faceNormalVector)
                  VectorLength = swParallelCheck.GetLength
                  If VectorLength = 0 Then
                      If surf Then
                          If bCoin Then
                              myFace.Select True
              Next faceCount
              swModelName = swModel.GetPathName
              swPathName = swModel.GetPathName
              swPathSize = Strings.Len(swPathName)
              swPathNoExtension = Strings.Left(swPathName, swPathSize - 17)
              swNewFilePath = swPathNoExtension & "Waterjet Files\"
              If Len(Dir(swNewFilePath, vbDirectory)) = 0 Then
                  MkDir (swNewFilePath)
              swFileName = swModel.GetTitle
              swNameSize = Strings.Len(swFileName)
              swNewFileName = Strings.Left(swFileName, swNameSize - 6)
              swPathName = Left(swPathName, InStrRev(swPathName, "\"))
              swPathName = swNewFilePath & swNewFileName & "dxf"
             If Dir(swPathName) <> "" Then Kill swPathName 'Add this code to delete the file if it already exists
              dataAlignment(0) = 0#
              dataAlignment(1) = 0#
              dataAlignment(2) = 0#
              dataAlignment(3) = 1#
              dataAlignment(4) = 0#
              dataAlignment(5) = 0#
              dataAlignment(6) = 0#
              dataAlignment(7) = 0#
              dataAlignment(8) = 0#
              dataAlignment(9) = 0#
              dataAlignment(10) = 1#
              dataAlignment(11) = 0#
              varAlignment = dataAlignment
              dataViews(0) = ""
              varViews = dataViews
              swPart.ExportToDWG swPathName, swModelName, 2, True, varAlignment, False, False, 0, Null
              Deepak Gupta
              Nick, can you give it a shot. Please try on sample files first.
              This has been tested on SW2014 SP3 Win 7 x64. So in case you've lower version of SW, you may need to fix the reference libraries in the macro.
              Also this works for one face at a time. I'll try I can modify it further to add multiple faces.
                  Nick Hayman
                  Hi Deepak,
                  It works at my end thanks.
                  Ive tested it with chamfers on holes and it produces a dwg which shows the outer edge of the chamfer rather than the hole itself. I can suppress the chamfer before i create it but was just wondering if it was meant to do that within the macro? It would make sense that i supress the chamfer select the face, run the macro and then unsupress the chamfer.
                  One more thing i have noticed is that it will not produce a dwg of a flat part WITH bendlines on. Can this be achieved or is there another macro out there for sheet metal parts only which has this functionality? Maybe this could be written in? Do you get the same results?
                  Thanks Again
                  Nick
