6 Replies Latest reply on Jun 3, 2014 7:19 PM by Artem Taturevych
    Addin.dll does not contain any types that can be registered for COM Interop warning
    Abhijit Dubal
      Hi Everyone...
      I am trying to register a .dll file in COM.But it is failing and warnings are coming:
      C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(935,9): warning MSB3391: "c:\users\acd92078.myttl\documents\visual studio 2010\Projects\SWADDIN_Test\SWADDIN_Test\bin\Debug\SWADDIN_Test.dll" does not contain any types that can be unregistered for COM Interop.
      C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(3341,9): warning MSB3214: "c:\users\acd92078.myttl\documents\visual studio 2010\Projects\SWADDIN_Test\SWADDIN_Test\bin\Debug\SWADDIN_Test.dll" does not contain any types that can be registered for COM Interop.
      I have tried all the suggestions that were given previously in one of the discussions on similar error on PC review.
      This is my Code:-
      using System;
      using System.Collections;
      using System.Reflection;
      using System.Collections.Generic;
      using System.Linq;
      using System.Text;
      using SolidWorks.Interop.sldworks;
      using SolidWorks.Interop.swcommands;
      using SolidWorks.Interop.swconst;
      using SolidWorks.Interop.swpublished;
      using SolidWorksTools;
      using SolidWorksTools.File;
      using System.Runtime.InteropServices;
      using System.Diagnostics;
      namespace SWADDIN_Test
      [ComVisible(true)]
      [Guid("6701cbb8-ee73-46ed-bbe5-8a80c9a0280b")]
      [InterfaceType(ComInterfaceType.InterfaceIsIDispatch)]
      interface ISWIntegration
      void DoSWIntegration();
      }//end of interface Dummy ISWIntegration
      [ClassInterface(ClassInterfaceType.AutoDual)]
      [ProgId("SWADDIN_Test.SWIntegration")]
      [ComVisible(true)]
      public class SWIntegration : ISwAddin, ISWIntegration
      public SldWorks mSWApplication;
      private int mSWCookie;
      public SWIntegration()
      { }//end of parametereless constructor
      public void DoSWIntegration()
      { }//end of dummy method DoSWIntegration
      public bool ConnectToSW(object ThisSW, int Cookie)
      mSWApplication = (SldWorks)ThisSW;
      mSWCookie = Cookie;
      // Set-up add-in call back info
      bool result = mSWApplication.SetAddinCallbackInfo(0, this, Cookie);
      this.UISetup();
      return true;
      }//end of method ConnectToSW()
      public bool DisconnectFromSW()
      return UITeardown();
      }//end of method DisconnectFromSW()
      public void UISetup()
      { }//end of method UISetup()
      public bool UITeardown()
      return true;
      }//end of method UITeardown()
      [ComRegisterFunction()]//Attribute
      private static void ComRegister(Type t)
      string keyPath = String.Format(@"SOFTWARE\SolidWorks\AddIns\{0:b}", t.GUID);
      using (Microsoft.Win32.RegistryKey rk = Microsoft.Win32.Registry.LocalMachine.CreateSubKey(keyPath))
      rk.SetValue(null, 1);// Load at startup
      rk.SetValue("Title", "Abhijit's SwAddin"); // Title
      rk.SetValue("Description", "All your pixels now belong to us"); // Description
      }//end of using statement
      }//end of method ComRegister()
      [ComUnregisterFunction()]//Attribute
      private static void ComUnregister(Type t)
      Microsoft.Win32.Registry.LocalMachine.DeleteSubKeyTree(keyPath);
      }//end of method ComUnregister()
      }//end of class SWIntegration
      }//end of namespace SWADDIN_Test
      Kindly suggest me a solution on this.
      Thanks in advance.
      -Abhijit
