10 Replies Latest reply on Jun 13, 2014 10:17 AM by Sanya Shmidt
    Search custom properties in EPDM database using API
    Sanya Shmidt
      Hi guys,
      I`m working on a part configurator which will be creating unique ID# for the generated part. ID# will be assigned to a custom propery.
      I`m curious if there is a way to search for the custom property in EPDM using API calls?
      For example user will type all part parameters in the configurator. ID will be generated in the background. After user clicks generate part, I want to search in EPDM for matching ID`s and give user a suggestion that part with these parameters already exists.
      Any help is appreciated.
      Alex.
        • Re: Search custom properties in EPDM database using API
          Artem Taturevych
          You cannot search y custom properties directly but you can search by ePDM variable. Use this method: IEdmSearch5::AddVariable. Take a look at the examples available under the IEdmSearch5 interface.
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
            Markku Lehtola
            I'm using Excel based search tool to check if part exists and get some custom property info, let me know if you're interested..
            Performance is pretty much the same as searching by hand I think..
            br
            Markku
            www.sloworks.fi
                Sanya Shmidt
                Markku thanks,
                Would be great if you could share a part of a code. I do have an app that works with excel, searches , adds new parts. I guess I can use same engine. Below is what I used in a different other then SW area.
                'Checking database Searching Excel document
                    Private Sub but_check_Click(sender As Object, e As EventArgs) Handles but_check.Click
                If File.Exists(pathfile) = False Then
                            MsgBox("Database doesn`t exist or network is down.", MsgBoxStyle.Critical, "Warning!!!")
                            Exit Sub
                        Dim xlApp As New Excel.Application
                        Dim xlWb As Excel.Workbook
                        Dim xlsheet As Excel.Worksheet
                        Dim i As Integer
                        lbl_Sswitch.Visible = False
                        With xlApp
                            .Visible = False
                            '~~> Open workbook
                            xlWb = .Workbooks.Open(pathfile)
                            '~~> Set it to the relevant sheet
                            xlsheet = xlWb.Sheets("P17885")
                            On Error GoTo CantFindSwitch
                            bar_1.Visible = True : lbl_searching.Visible = True
                            With xlsheet
                                lastrow = .Range("A" & .Rows.Count).End(Excel.XlDirection.xlUp).Row ' last row
                                ReDim P17885(lastrow + 1, 2)
                                For i = 1 To lastrow
                                    P17885(i, 1) = xlsheet.Cells(i, 1).Value
                                    P17885(i, 2) = xlsheet.Cells(i, 4).Value
                                    bar_1.Maximum = lastrow
                                    bar_1.Step = 1
                                    bar_1.PerformStep()
                                    If P17885(i, 2) = txt_des_level1.Text Then
                                        lbl_Sswitch.Visible = True 'txt_existPart.Visible = True
                                        lbl_Sswitch.Text = P17885(i, 1) : switch_exist = True
                                        Exit For
                                Next
                            End With
                        End With
                        bar_1.Value = 0
                        'bar_1.Visible = False
                        lbl_searching.Visible = False
                        If switch_exist = True Then
                            switch_exist = False
                            GoTo ClearVars
                CantFindSwitch:
                        If MsgBox("Cant find switch. Would you like to add it?", MsgBoxStyle.YesNo, "Warning!") = MsgBoxResult.No Then
                            GoTo ClearVars
                        Else
                            gbox_2.Enabled = True
                            txt_level1.Text = txt_des_level1.Text
                                   lbl_NewSwitchNum.Visible = True
                            lbl_NewSwitchNum.Text = "P17885-" + CStr(i - 1)
                            txt_JN.Select()
                ClearVars:  '~~> Close workbook and quit Excel
                        xlWb.Close(False)
                        xlApp.Quit()
                        xlApp = Nothing
                        xlWb = Nothing
                        xlsheet = Nothing
                  'adding switch to the database
                    Private Sub but_add_Click(sender As Object, e As EventArgs) Handles but_add.Click
                      If txt_JN.Text = "" Then
                            MsgBox("Job number is required field.", MsgBoxStyle.Exclamation, "Warning!")
                            txt_JN.Select()
                            Exit Sub
                        If cbox_description.SelectedIndex = -1 Then
                            MsgBox("Description is required field.", MsgBoxStyle.Exclamation, "Warning!")
                            cbox_description.Select()
                            Exit Sub
                            Exit Sub
                        '~~> Open workbook
                        lastrow = 0
                        With xlApp
                            xlsheet.Activate()
                            ' adding new record
                            With xlApp
                                .Range("A" + CStr(lastrow + 1)).Select()
                                .ActiveCell.FormulaR1C1 = "P17885-" + CStr(lastrow)
                                .Range("B" + CStr(lastrow + 1)).Select()
                                .ActiveCell.FormulaR1C1 = txt_JN.Text
                                .Range("C" + CStr(lastrow + 1)).Select()
                                .ActiveCell.FormulaR1C1 = cbox_description.SelectedItem
                                .Range("D" + CStr(lastrow + 1)).Select()
                                .ActiveCell.FormulaR1C1 = txt_level1.Text
                            End With
                        End With
                        MsgBox("Switch P17885-" + CStr(lastrow) + " added. Please write down part number.", MsgBoxStyle.OkOnly, "Switch added")
                        txt_level1.Text = ""
                        txt_JN.Text = ""
                        txt_des_level1.Text = "1.00" : txt_des_level1.SelectionStart = 0
                        txt_des_level1.SelectionLength = 4 : txt_des_level1.Select()
                        lbl_NewSwitchNum.Visible = False
                        gbox_2.Enabled = False
                        'System.Threading.Thread.Sleep(10000)
                TheEnd:
                        xlWb.Close(True)
                        xlApp.Quit()
                        xlApp = Nothing
                        xlWb = Nothing
                        xlsheet = Nothing
                    Markku Lehtola
                    Here's the base of the search code. Idea is to check are item numbers found in EPDM and if yes, then read some stuff. hope it helps..
                    Sub SearchEDM()
                    Dim swModel As ModelDoc2
                    Const swDocPart = 1
                    Const swDocAssembly = 2
                    Sheets("Sheet1").Activate
                    'login to vault
                    Dim objVault As IEdmVault8
                    Const vaultname As String = "EDM"
                    Set objVault = New EdmVault5
                    objVault.LoginAuto vaultname, 0
                    Dim search As IEdmSearch7
                    Dim DescriptionID As Integer
                    Dim sr As IEdmSearchResult5
                    'clear old search results
                    Worksheets("Sheet1").Columns(6).ClearContents
                    Worksheets("Sheet1").Columns(7).ClearContents
                    Worksheets("Sheet1").Columns(8).ClearContents
                    Worksheets("Sheet1").Columns(4).ClearContents
                    Worksheets("Sheet1").Columns(13).ClearContents
                    'item number row count from column E
                    LastRow = Worksheets("Sheet1").Range("E65536").End(xlUp).Row
                    For i = 1 To LastRow
                      Set search = objVault.CreateSearch
                              'B2= folder, eg. C:\EDM\COMPONENT LIBRARY
                        search.AddVariable Range("B2").Text, "%" & Range("E" & i).Text
                        Dim retval As Boolean
                        'search options
                        search.FindFiles = True
                        search.FindFolders = False
                        search.Filename = "%.sldprt"
                        search.SetToken Edmstok_AllVersions, False
                        Set sr = search.GetFirstResult
                        If sr Is Nothing Then
                        Else
                              'fill columns with data if item number in column E is found in EDM
                        Range("G" & i).Value = sr.Path
                        Range("H" & i).Value = sr.Name
                        Range("G" & i).Activate
                    'read item numbers and if match found with N-prefix then get the configuration name from the model for
                    'that item number
                       Dim File As IEdmFile8
                       Dim Folder As Object
                            Set File = objVault.GetFileFromPath(sr.Path, Folder)
                            Dim cfgList As EdmStrLst5
                            Set cfgList = File.GetConfigurations
                            Dim pos As IEdmPos5
                            Dim pEnumVar As Object
                            Set pEnumVar = File.GetEnumeratorVariable
                            Dim Value As Variant
                            VariableName = "Item Number"
                            Set pos = cfgList.GetHeadPosition
                            Dim cfgName As String
                                While Not pos.IsNull
                                    cfgName = cfgList.GetNext(pos)
                                    If pEnumVar.GetVarFromDb(VariableName, cfgName, Value) Then
                                        If Right(Value, 6) = Range("E" & i).Text Then
        If Left(Value, 1) = "N" Then
                                                Range("D" & i).Value = "N"
                                                Range("M" & i).Value = cfgName
                                    Else
                                Wend
                    'add link to model
                        If Dir(sr.Path) <> "" Then
                            ActiveCell.Formula = "=HYPERLINK(" & Chr(34) & sr.Path & Chr(34) & "," & """Open model""" & ")"
                    Next i
                    MsgBox ("Search finished")
