Issues with dimensioning components created from a part file
Question asked by Lenny Dichiara on May 29, 2014
Latest reply on May 29, 2014 by Glenn Schroeder
Hi All -
I had a question which hopefully someone can shed some light onto.
I have created a part file (in this case, it is a key chain) and I am trying to dimension
the components but I am having no luck getting SW to recognize the lines that I am
trying to use to dimension my part.
I think I know the reason why - but not sure if there is a workaround.
I created the key ring portion of my design using a circle which I then built a helix from and
did a swept path to create the part.
Normally what I will do if i have issues referencing a line I'll set a point and create a coincident
reference on the line with the point but this is not working either.
I believe it is because the swept lines from the helix is geometry created from two profiles and
I need to pull the point from an area of the part that has been interpolated.
Does anyone have any advice on how to get this resolved or is there a way to do it? I would think
there has to be as all I am trying to get is an overall dimension - very basic stuff.
Lenny
