2 Replies Latest reply on May 29, 2014 6:11 AM by Abhijeet Katkar
    File Deletion
    Donald Scribner
      I'd like to click a button and have a SW macro delete all files in the folder that don't reside in the assembly that I am currently in or.  Any takers?
        • Re: File Deletion
          Anna Wood
          Alternate solution.....
          Create a dummy Windows directory folder someplace on your computer.  Maybe call it Junk...
          Close your session of SolidWorks and re-open to clean up anything that may be loaded in RAM.
          Open the assembly you want to clean up in SolidWorks.
          Select and Move all the files in your assembly folder into the dummy folder.
          You will get a dialog box from Windows that says it can't move all the files.  Acknowledge and let Windows move the files it can (the ones not open in SolidWorks).
          Your Junk folder will contain all the files not needed by your current assembly.  Delete when you are comfortable that you do not need the files anymore.
          Cheers,
          Anna
          • Re: File Deletion
            Abhijeet Katkar
            And if you hate creating dummy Junk folder, create dummy work folder, Pack & Go the assembly with drawings to new folder & delete original folder completely & this way you can get read of unwanted drawings as well. ( In Anna's solution you need to do it manually for drawings)
