Since we just started using enterprise PDM, we have some files from the past that were saved, with the same file name, but in different folders: rev A, rev B, rev C, etc.
I'd like to 1 by 1 add these into the vault, but have them all be new revisions of the same file. Is this possible? I have a workflow that allows me to set the revision number on a part. The problem is I copy/paste the first part and check in then work it through and set to Rev A. Then I copy/paste the second part into the same folder, but I can't set it to the same file name as the first part. All I'm able to do is set the revision to B.
Anyone know how to get around this issue?
Travis
check out the rev A file. save over it with the rev B file and check it in and make it rev B. repeat as needed.
(note details are left vague because we do not know your workflow)
