Hello guys,
When I open an large assembly form PDM I have to wait a very long time (about 30 minutes).
This is acceptable if the large assembly is opened for the first time, but when the assembly is loaded in to the workspace this shouldn't happened.
Also when the assembly is finally opened I can not do anything because the solid works is working very slow.
If I want to open a simple part from the assembly that is already opened I have to wait another 20 minutes.
I spoke with my IT guys and they restarted the server and nothing was changed.
After several attempts I discover that if I clean my workspace and restart the server, I still wait 30 minutes for a large assembly to download from the PDM but if I try to open a simple part the waiting time is reduced to 15 seconds.
If I close all the parts and the assemblies and try to open again the time increase to 25 minutes per assembly and 20 minutes per part.
Does anyone encounter this behavior on PDM and solid works?
I do not want to clean my workspace and restart the server every time when the solidworks is closed.
Can anyone came up with a solution for this problem?
You will get a better set of answers if you tell us more about your system specs (memory, graphics, etc).
At first reading, I was suspecting it could be related to the type of parts - swoopy, curvey with transparent appearances can take longer to open but after restarting you say they open much faster. Where are your parts being saved after opening from PDM vault? If they are being save on your local drive, they will respond faster than if being pulled from a server.
I suspect the problem is not with the PDM vault, but with the parts/assy's themselves.
You may want to check a couple of settings. First, in the PDM Vault admin, see if verification is set "on" fulltime. Second, check the settings in "tools, options" as shown in the attachment.
