4 Replies Latest reply on May 29, 2014 12:43 PM by Klaudiusz Skiba
    Changing color of dimension on solidwork drawing
    Klaudiusz Skiba
      Hi all, this is my first official post, but not last.
      I'm using Solidworks 2013 SP3
      I'm in the process of creating auto balloning macro that does few extra things.
      I'm adding ballons using displaydimension and placing on either side <#-1> so i get balloons
      My problem is that i would like to make those ballons red but leave dimensions black.
      Any pointers are highly welcome.
      Claud
        • Re: Changing color of dimension on solidwork drawing
          Klaudiusz Skiba
          Does anybody have a clue if that is even doable? To clarify I'm only looking for change color of dimension. No need for whole code just some pointers.
              Artem Taturevych
              Could you please send the sample part with such dimension? Not sure how exactly you added the baloon to display dimension.
                  Klaudiusz Skiba
                  Thank you for reply.
                  Ok here is the part of the code for adding balloons, it's from a macro I found on the forum.
                  My goal is to be able to set  sNewSuffix  to be red. I tried few aproaches but couldn't get it.
                  Dim swDoc As SldWorks.ModelDoc2
                  Dim swDwg As SldWorks.DrawingDoc
                  Dim swView As SldWorks.View
                  Dim swDispDim As SldWorks.DisplayDimension
                  Dim swDim As SldWorks.Dimension
                  Dim sCurSuffix As String
                  Dim nOpenParPos As Long
                  Dim nCloseParPos As Long
                  Dim vDimVal As Variant
                  Dim dInchVal As Double
                  Dim sInchString As String
                  Dim sNewSuffix As String
                  Global Killflag As Integer
                  Global locationSelection As String
                  Dim sMsg As String
                  Public sRefPfx As String
                  Global nRefNum As Long
                  Const DEFSYM As String = "C#-"
                  Public Function AddDimRefNums()
                  Set swDoc = swApp.ActiveDoc
                  If swDoc.GetType <> swDocDRAWING Then
                      MsgBox "This macro only works for drawing files."
                      Exit Function
                  sRefPfx = DEFSYM
                  Set swDwg = swDoc
                  If nRefNum < 1 Then
                  nRefNum = 1
                  Set swView = swDwg.GetFirstView
                  While Not (swView Is Nothing)
                      Set swDispDim = swView.GetFirstDisplayDimension5
                      While Not swDispDim Is Nothing
                          Set swDim = swDispDim.GetDimension
                          sInchString = sRefPfx & nRefNum
                          nRefNum = nRefNum + 1
                          sCurSuffix = swDispDim.GetText(locationSelection)
                          nOpenParPos = 0
                          nCloseParPos = 0
                          If sCurSuffix Like "*<" & Replace(sRefPfx, "#", "[#]") & "*>*" Then
                              nOpenParPos = InStr(1, sCurSuffix, "<" & sRefPfx, vbTextCompare)
                              nCloseParPos = InStr(nOpenParPos, sCurSuffix, ">", vbTextCompare)
                          If (Killflag = vbNo) And (nOpenParPos > 0) And (nCloseParPos > 0) Then
                              sNewSuffix = Left(sCurSuffix, nOpenParPos - 1)
                              sNewSuffix = sNewSuffix & Right(sCurSuffix, Len(sCurSuffix) - nCloseParPos)
                          ElseIf (nOpenParPos > 0) And (nCloseParPos > 0) Then
                              sNewSuffix = Left(sCurSuffix, nOpenParPos)
                              sNewSuffix = sNewSuffix & sInchString
                              sNewSuffix = sNewSuffix & Right(sCurSuffix, Len(sCurSuffix) - (nCloseParPos - 1))
                          Else
                              If Killflag <> vbNo Then
                                  sNewSuffix = Trim(sCurSuffix) & " <" & sInchString & ">"
                              Else
                                  sNewSuffix = sCurSuffix
                          swDispDim.SetText locationSelection, sNewSuffix
                          Set swDispDim = swDispDim.GetNext5
                      Wend
                      Set swView = swView.GetNextView
                  Wend
                  End Function
                Klaudiusz Skiba
                The only solution I can see to it is to create balloons in notes that are associated with dimensions.
