5 Replies Latest reply on Jan 4, 2017 9:50 AM by Kishore K.
    sweep command api example
    Vishaldeep Singh
      some example of sweep command with api code
        • Re: sweep command api example
          Deepak Gupta
          Check the example "Insert Sweep Cut Feature Example (VBA)" in SW API help files. You can use the same for InsertProtrusionSwept3
            Manikandan Babu
            Dear Vishal,
                                 Macro for sweep command
            Option Explicit
            Dim swmodel As SldWorks.ModelDoc2
            Dim swpart As SldWorks.PartDoc
            Dim tempdir As String
            swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
            tempdir = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplatePart)
            Set swmodel = swApp.NewDocument(tempdir, 0, 0, 0)
            swmodel.Extension.SelectByID2 "Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0
            swmodel.SketchManager.InsertSketch True
            swmodel.ShowNamedView ("*Normal To")
            'Path
            swmodel.SketchManager.CreateLine 0, 0, 0, 0, 100 / 1000, 0
            swmodel.AddDimension 15 / 1000, 15 / 1000, 0
            swmodel.SketchManager.CreateLine 0, 100 / 1000, 0, 100 / 1000, 100 / 1000, 0
            'Profile
            swmodel.Extension.SelectByID2 "Top Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0
            swmodel.SketchManager.CreateCircleByRadius 0, 0, 0, 25 / 1000
            swmodel.AddDiameterDimension2 0, 10 / 1000, 0
            'Sweep
            swmodel.Extension.SelectByID2 "Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0
            swmodel.Extension.SelectByID2 "Sketch2", "SKETCH", 0, 0, 0, True, 0, Nothing, 0
            swmodel.FeatureManager.InsertProtrusionSwept3 True, True, 0, False, False, 0, 0, True, 2 / 1000, 0, 1, 0, True, True, True, 0, False
            Manikandan B
            EGS Computers India Pvt Ltd
            http://www.egsindia.com
            http://www.egs.co.in
