13 Replies Latest reply on Oct 3, 2014 1:59 PM by Wes Cox
    Re-naming Sketches & Bodies using API
    Nick Hayman
      Afternoon All,
      I would like to re-name sketches and bodies within a part.
      I do not want to select the sketch and then rename it because i would have to know the name of the sketch in the first place which i do not know. Also, I may not know how many bodies are within the part. I would like to work my way down from the model tree renaming (in a pattern) as i go untill all skecthes and bodies have been renamed.
      Bodies (See parts attached):
      The first body will be called A1. The 3rd body will be called A2 and the fifth body will be called A3.
      This will leave the second body renamed as B1 and the fourth as B2 and so on.
      I would like this to happen untill all bodies within the part are renamed.
      Sketches (See parts attached):
      The skecth within the body will need to be renamed.
      So the sketch in the first body will be called AA1, The third AA2, and the fifth AA3.
      The second as BB1 and fourth as BB2.
      Ive attached an example before and after to show what i am looking for.
      I suppose the first thing to ask is can SW rename bodies and skecthes in this way? Rather than selecting by name.
      Many Thanks in advance.
      Nick
        • Re: Re-naming Sketches & Bodies using API
          Deepak Gupta
          Yes this should be possible.
              Nick Hayman
              Any ideas how i go about this Deepak?
                    Nick Hayman
                    Thanks Deepak,
                    A few issues:
                    1.     It renames everything in the model tree. I want just the Sketches and extrudes to be renamed. Not the folders and planes & origin.
                    2.     It doesnt rename the sketches in the tree.
                    3.     It hasnt renamed the first extrude.
                    4.     Its renamed the bodies as ICE yet i cannot see thisin the code. Have i gone blind?
                    Can you help me with this?
                    Many Thanks
                    Nick
                        Deepak Gupta
                        I believe that is something internal. Scroll down in the post and you would see some more updated macros from him which you can try/use.
                            Nick Hayman
                            The latest macro sorts out the issues with the default planes and material but not the Sensors or annotations.
                            It also does not rename the sketches within the extrudes on my example part (Before).
                            So we are half way there! But not all the way
                            This is a bit beyond my skills... although i am learning... sloowwwwly.
                            Anything you can do?
                                Nick Hayman
                                I only want to rename bodies and sketches. Nothing else.
                                    Ivana Kolin
                                    Dim swFeat As SldWorks.Feature
                                    Dim tempFeat As SldWorks.Feature
                                    Dim swFeature As SldWorks.Feature
                                    Dim newName As String
                                    Dim newNameCount As Integer
                                    Dim dicFeatsCount As Object
                                    Dim parents As Variant
                                        Set dicFeatsCount = CreateObject("Scripting.Dictionary")
                                        Set collFeatsNonIncr = New Collection
                                        Set dicBaseNames = CreateObject("Scripting.Dictionary")
                                        isRefGeom = False
                                        'Add the list of predefined base names
                                        dicBaseNames.Add "Extrusion", "A"
                                        dicBaseNames.Add "Boss", "B"
                                        Set swPart = swApp.ActiveDoc
                                        Set swFeat = swPart.FirstFeature
                                        While Not swFeat Is Nothing
                                            If dicFeatsCount.exists(swFeat.GetTypeName()) Then
                                                dicFeatsCount.Item(swFeat.GetTypeName()) = dicFeatsCount.Item(swFeat.GetTypeName()) + 1
                                            Else
                                                dicFeatsCount.Add swFeat.GetTypeName(), 1
                                            If dicBaseNames.exists(swFeat.GetTypeName()) Then
                                                newName = dicBaseNames.Item(swFeat.GetTypeName())
                                                newNameCount = dicFeatsCount.Item(swFeat.GetTypeName())
                                                Set tempFeat = swPart.FeatureByName(newName & newNameCount)
                                                If Not tempFeat Is Nothing Then
                                                 tempFeat.Name = swFeat.Name & newName & newNameCount
                                                swFeat.Name = newName & newNameCount
                                                parents = swFeat.GetParents
                                                For Each varobj In parents
                                                    Set swFeature = varobj
                                                    If swFeature.GetTypeName = "ProfileFeature" Then
                                                        swFeature.Name = newName & newName & newNameCount
                                                Next varobj
                                            Set swFeat = swFeat.GetNextFeature
                                        Wend
                                        Nick Hayman
                                        Hi Ivana,
                                        Thankyou for your reply.
                                        It doesnt quite work. Close but not quite.
                                        It has renamed the first body as A1 and the sketch within as AA1. It renames the second body as B1 and the sketch within as BB1. This is correct.
                                        After that it renames the body and sketches as B2 & BB2, B3 & BB3, B4 & BB4 which is incorrect.
                                        It should be:
                                        A1, AA1
                                        B1, BB1
                                        A2, AA2
                                        B2, BB2
                                        A3, AA3
                                        B3, BB3
                                        Etc...
                                        Very close! Can you help further?
                                            Nick Hayman
                                            Id also like the option to change the letters within the macro.
                                            This is an example i might require::
                                            F1, FL1
                                            HL1, WHL1
                                            F2, FL2
                                            HL2, WHL2
                                            F3, FL3
                                            HL3, WHL3
                                            Is this achieveable?
                                                Ivana Kolin
                                                Option Explicit
                                                Dim newSketchName As String
                                                Dim FLCount As Integer
                                                Dim HLCount As Integer
                                                Dim varobj As Variant
                                                    FLCount = 1
                                                    HLCount = 1
                                                        Select Case swFeat.GetTypeName
                                                        Case "Extrusion", "Boss"
                                                            If FLCount = HLCount Then
        newName = "F"
        newSketchName = "FL"
        newNameCount = FLCount
        FLCount = FLCount + 1
                                                            Else
        newName = "HL"
        newSketchName = "WHL"
        newNameCount = HLCount
        HLCount = FLCount
                                                             tempFeat.Name = swFeat.Name & "<renamed>"
        swFeature.Name = newSketchName & newNameCount
                                                            Next varobj
                                                        Case Else
                                                            Debug.Print swFeat.GetTypeName
                                                        End Select
                                                    Wend
                              Nick Hayman
                              Thanks to all.
                              Perfect!
                                  Wes Cox
                                  For some reason when I try to run this (Correct answer from Ivana), nothing happens-- am I missing something painfully obvious? Yes, got it. I've tried creating this several times with no run. SW2010. Do I need some other references or something else enabled? Does anyone have a copy of this macro working that they'd be willing to share? Thank you!
                                  I expected this macro to rename bodies, but from what I'm seeing it only renames features. I was running it on an imported part that only had imported bodies in the tree, and the macro was having no effect. Once I tried it on a part that contained features, I saw the macro was running fine.
                                  I'm trying to rename all bodies of an imported part, without altering the name of the folders, planes etc at top of tree.
                                  This macro is close, except that it renames the default folders etc. http://eng-tips.com/viewthread.cfm?qid=250003
                                  Boom! Got it-- excited, this is one of the more difficult edits I've made yet, it just didn't make sense to me for a while:
                                  Dim collFeatsNonIncr As Collection
                                  Dim dicBaseNames As Object
                                  Const FrontPlane = "Front Plane"
                                  Const TopPlane = "Top Plane"
                                  Const RigthPlane = "Right Plane"
                                  Const Origin = "Origin"
                                  Const DetailCabinet = "Annotations"
                                  Dim isRefGeom As Boolean
                                      isRefGeom = False
                                      'Add the list of features which shouldn't be incremented
                                      collFeatsNonIncr.Add "SensorFolder"
                                      collFeatsNonIncr.Add "DocsFolder"
                                      collFeatsNonIncr.Add "DetailCabinet"
                                      collFeatsNonIncr.Add "MaterialFolder"
                                      collFeatsNonIncr.Add "OriginProfileFeature"
                                      collFeatsNonIncr.Add "EqnFolder"
                                      collFeatsNonIncr.Add "EnvFolder"
                                      dicBaseNames.Add "MaterialFolder", "Material <not specified>"
                                      dicBaseNames.Add "OriginProfileFeature", "Origin"
                                      dicBaseNames.Add "ProfileFeature", "Sketch"
                                      dicBaseNames.Add "Extrusion", "Extrude"
                                      dicBaseNames.Add "RefPlane", "Plane"
                                      dicBaseNames.Add "DetailCabinet", "Annotations"
                                      dicBaseNames.Add "EqnFolder", "Equations"
                                      dicBaseNames.Add "EnvFolder", "Lights, Cameras & Scenes"
                                          If dicFeatsCount.exists(swFeat.GetTypeName2()) Then
                                              dicFeatsCount.Item(swFeat.GetTypeName2()) = dicFeatsCount.Item(swFeat.GetTypeName2()) + 1
                                          Else
                                              dicFeatsCount.Add swFeat.GetTypeName2(), 1
                                          If dicBaseNames.exists(swFeat.GetTypeName2()) Then
                                              newName = dicBaseNames.Item(swFeat.GetTypeName2())
                                          Else
                                              newName = swFeat.GetTypeName2()
                                          Dim i As Integer
                                          Dim isIncremented As Boolean
                                          isIncremented = True
                                          For i = 1 To collFeatsNonIncr.Count
                                              If collFeatsNonIncr(i) = swFeat.GetTypeName2() Then
                                                  isIncremented = False
                                                  Exit For
                                          Next
                                          If isIncremented Then
                                              newName = newName & dicFeatsCount.Item(swFeat.GetTypeName2())
                                          If swFeat.GetTypeName2 = "MaterialFolder" Then
                                              isRefGeom = True
                                              Dim sMatName As String
                                              sMatName = swPart.GetMaterialPropertyName2("", "")
                                              If sMatName <> "" Then
                                                  newName = sMatName
                                          If isRefGeom Then
                                              swFeat.Name = FrontPlane
                                              swFeat.Name = TopPlane
                                              swFeat.Name = RigthPlane
                                              swFeat.Name = Origin
                                              isRefGeom = False
                                      Wend
