4 Replies Latest reply on May 28, 2014 8:03 AM by Fg Ning
    how to Reset the rotate angle of move/copy feature by API
    Fanggang Ning
      dear all
      i want to use SolidWorks API to change the  rotate angle of move/copy feature,shown as below
      Set Part = swApp.ActiveDoc
      Set moveCopyFeat = Part.FeatureByName("实体-移动/复制1")
      Set moveCopy_featData = moveCopyFeat.GetDefinition
      copycount = moveCopy_featData.GetBodiesCount
      boolstatus = Part.EditRebuild3()
      Part.ClearSelection2 True
      in fact ,i don't know how to change or Reset the relevant parameters in feature mainly because i couldn't get these parameter name .
      for instance ,in sketch ,it's easy to get the name by record macro file "part.Parameter("D1@" & "曲面-扫描1@CLK-1")"
      while when i modify parameters in feature ,for example ,the rotate angle mentioned above , the macro couldn't record this process ,which lead to the difficulties  for me to modify the parameters that i need to change .
      many thanks
        • Re: how to Reset the rotate angle of move/copy feature by API
          Artem Taturevych
          Try this:
          moveCopy_featData.AccessSelections Part, Nothing
          moveCopy_featData.TransformValue = 1.57 'angle in radians
          moveCopyFeat.ModifyDefinition moveCopy_featData, Part, Nothing
              Fg Ning
              hi ,Artem
              thank you for your timely reply !
              yes ,
              Set movecopyfeat = assembly.FeatureByName("实体-移动/复制1@CLK-1@8STRANDBRAID")
              can works very well ,while when i put this section into an assembly ,the red linehas some problems .could mind solve this for me .
              thanks
                  Artem Taturevych
                  In assembly you need to pass the pointer to the component instead of Nothing:
                  moveCopy_featData.AccessSelections Part, swComp
                  moveCopyFeat.ModifyDefinition moveCopy_featData, Part, swComp
                  where
                  Dim swComp as SldWorks.Component2
                  Set swComp = moveCopyFeat.GetComponent()
                  but if you are saying that the red line is failing (I assume you have null-reference exception: Object or with block variable not set) make sure that the name of the feature is correct (i.e. 实体-移动/复制1@CLK-1@8STRANDBRAID) because it is NULL in this case.
                      Fg Ning
                      dear Artem,
                      thank you for your advice .
                      now the programming workshop smoothly,while when i check the effect. i find the angle was not changed ,
                      Dim swApp As Object
                      Dim part As Object
                      Dim assembly As Object
                      Dim boolstatus As Boolean
                      Dim Annotation As Object
                      Dim Feature As Object
                      Dim FeatureData As Object
                      Dim myDisplayDim As Object
                      Dim myDimension As Object
                      Set part = swApp.ActiveDoc
                          Set moveCopyFeat = part.FeatureByName("实体-移动/复制1")
                      moveCopy_featData.AccessSelections part, Nothing
                      moveCopyFeat.ModifyDefinition moveCopy_featData, part, Nothing
                      can you check it for me
