I am currently trying to run analysis on my aircraft wing design but am continuosly getting meshing errors. I have checked interference and it is saying there are no interfering parts. Also, the entire mesh does not fail. It fails to mesh half of one rib and the skin. What can I do to run analysis on my wing.
Try curvature based mesher.
You can also try to mesh separate parts to find problem.
You can also turn on incompatible mesh it helps when separate parts are able to mesh but assembly can't. This resolves meshing problems at shared boundaries but it also reduces result quality on those boundaries.
